  <title>CAD Forum discussion (EN) : model/ layout tabs</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : model/ layout tabs]]></description>
  <pubDate>Mon, 02 Nov 2026 12:51:13 +0000</pubDate>
  <lastBuildDate>Thu, 17 Jan 2008 18:46:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=402</WebWizForums:feedURL>
   <title><![CDATA[model/ layout tabs : Thanks, that solved it. The trick...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=402&amp;PID=937&amp;title=model-layout-tabs#937</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=4062">brenth</a><br /><strong>Subject:</strong> 402<br /><strong>Posted:</strong> 17.Jan.2008 at 18:46<br /><br /><P>Thanks, that solved it. The trick was to turn off the model tabs that are above the command line before you click the arrow. Otherwise the list will show that the buttons are active already.</P>]]>
   <pubDate>Thu, 17 Jan 2008 18:46:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=402&amp;PID=937&amp;title=model-layout-tabs#937</guid>
   <title><![CDATA[model/ layout tabs : Click on the small down-arrow...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=402&amp;PID=936&amp;title=model-layout-tabs#936</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 402<br /><strong>Posted:</strong> 17.Jan.2008 at 16:46<br /><br />Click on the small down-arrow on the bottom statusbar and in the list check the option Layout/Model. This will show the buttons.]]>
   <pubDate>Thu, 17 Jan 2008 16:46:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=402&amp;PID=936&amp;title=model-layout-tabs#936</guid>
   <title><![CDATA[model/ layout tabs : My model/layout tabs have dissappeared...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=402&amp;PID=935&amp;title=model-layout-tabs#935</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=4062">brenth</a><br /><strong>Subject:</strong> 402<br /><strong>Posted:</strong> 17.Jan.2008 at 16:40<br /><br />My model/layout tabs have dissappeared in autocad 2008. I go into option and turned them on and they now show above the comand line, like they did in previous version. Originally, they displayed in the status bar below the command line. It was my understanding that when you closed the tabs above the command line, they would automatically display in the status bar. Does anyone know how to make the Model/layout tabs to show up as buttons in the status bar?]]>
   <pubDate>Thu, 17 Jan 2008 16:40:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=402&amp;PID=935&amp;title=model-layout-tabs#935</guid>
