  <title>CAD Forum discussion (EN) : Please Help! AutoCAD FATAL ERROR</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Please Help! AutoCAD FATAL ERROR]]></description>
  <pubDate>Thu, 22 Oct 2026 06:55:42 +0000</pubDate>
  <lastBuildDate>Fri, 13 Aug 2010 22:20:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4121</WebWizForums:feedURL>
   <title><![CDATA[Please Help! AutoCAD FATAL ERROR : If you&amp;#039;re running Win7 you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10606&amp;title=please-help-autocad-fatal-error#10606</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=128767">Slaraffenmann</a><br /><strong>Subject:</strong> 4121<br /><strong>Posted:</strong> 13.Aug.2010 at 22:20<br /><br /><P>If you're running Win7 you could try this:</P><DIV><BR>1. Open command prompt. (RUN AS ADMINISTRATOR)<BR>2. Type the following text:&nbsp;&nbsp; bcdedit /set IncreaseUserVA 3072<BR>3. Restart computer.</DIV><DIV>This will make more memory avilable for applications, and less avilable for the operating system.</DIV><DIV>&nbsp;</DIV><DIV>Made a big difference at my computer.</DIV><DIV>&nbsp;</DIV><DIV>Sorry for any spelling mistakes.</DIV><span style="font-size:10px"><br /><br />Edited by Slaraffenmann - 13.Aug.2010 at 22:21</span>]]>
   <pubDate>Fri, 13 Aug 2010 22:20:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10606&amp;title=please-help-autocad-fatal-error#10606</guid>
   <title><![CDATA[Please Help! AutoCAD FATAL ERROR :  Copied from web: --&amp;gt;Uninstall...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10598&amp;title=please-help-autocad-fatal-error#10598</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=110392">hgf_21_xy</a><br /><strong>Subject:</strong> 4121<br /><strong>Posted:</strong> 13.Aug.2010 at 05:38<br /><br /><FONT color=#0000ff face="Verdana, Arial, Helvetica, sans-serif"><DIV>Copied from web:</DIV><DIV>--&gt;Uninstall the Microsoft .NET Framework.</DIV><DIV>--&gt;Uninstall AutoCAD.</DIV><DIV>--&gt;Restart the computer.</DIV><DIV>--&gt;Reinstall AutoCAD.</DIV><DIV>--&gt;Reinstall .NET Framework.</DIV><DIV>Hopefully the problem can be solved.<img src="http://www.cadforum.cz/forum_en/smileys/smiley2.gif" height="17" width="17" border="0" align="absmiddle" alt="Wink" /></DIV></FONT>]]>
   <pubDate>Fri, 13 Aug 2010 05:38:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10598&amp;title=please-help-autocad-fatal-error#10598</guid>
   <title><![CDATA[Please Help! AutoCAD FATAL ERROR : Sorry, where I wrote &amp;#034;......]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10592&amp;title=please-help-autocad-fatal-error#10592</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23520">p3.1416l</a><br /><strong>Subject:</strong> 4121<br /><strong>Posted:</strong> 12.Aug.2010 at 11:58<br /><br />Sorry, where I wrote "... to uninstall Frame Network..." I should have wrote "... to uninstall .NET Framework..."]]>
   <pubDate>Thu, 12 Aug 2010 11:58:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10592&amp;title=please-help-autocad-fatal-error#10592</guid>
   <title><![CDATA[Please Help! AutoCAD FATAL ERROR : As far as I know, that problem...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10591&amp;title=please-help-autocad-fatal-error#10591</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23520">p3.1416l</a><br /><strong>Subject:</strong> 4121<br /><strong>Posted:</strong> 12.Aug.2010 at 11:56<br /><br /><P>As far as I know, that problem could have thousands of causes but I think your only solution will be reinstall the program. Some people who had the same problem, told me that it had to do with&nbsp; .Net Framework&nbsp;Updates. They told they had to uninstall Frame Network and AutoCAD, then clean Windows Registry&nbsp;and then reinstall AutoCAD, wich includes .Net Framework 2.0</P>]]>
   <pubDate>Thu, 12 Aug 2010 11:56:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10591&amp;title=please-help-autocad-fatal-error#10591</guid>
   <title><![CDATA[Please Help! AutoCAD FATAL ERROR : So you&amp;#039;re doing professional...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10528&amp;title=please-help-autocad-fatal-error#10528</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4121<br /><strong>Posted:</strong> 04.Aug.2010 at 08:16<br /><br />So you're doing professional commercial work for an architect using the educational version of Autocad? <DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Wed, 04 Aug 2010 08:16:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10528&amp;title=please-help-autocad-fatal-error#10528</guid>
   <title><![CDATA[Please Help! AutoCAD FATAL ERROR : Hi all-  I am currently an architecture...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10523&amp;title=please-help-autocad-fatal-error#10523</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=127136">mccainkg</a><br /><strong>Subject:</strong> 4121<br /><strong>Posted:</strong> 03.Aug.2010 at 18:00<br /><br />Hi all-<DIV>&nbsp;</DIV><DIV>I am currently an architecture student and working as an intern for the summer. I have been working for a single architect and have been doing most of his work for him on Cad throughout the summer. I work on the AutoCAD 2010 Student Version, but have been able to coordinate with his older professional Cad drawings and making improvements /&nbsp;finalizing drawings. </DIV><DIV>&nbsp;</DIV><DIV>Just yesterday I tried opening a large file from his computer and my Cad instantly shut down stating: </DIV><DIV>&nbsp;</DIV><DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FATAL ERROR: Unhandled e0434f4dh Exception at 7c812afbh</DIV><DIV>&nbsp;</DIV><DIV>Since this, I cannot open anything on my AutoCad without this message popping up. I even tried opening previous drawings from my studio and it still shuts down. I have a Mac but work on a Bootcamp version of Windows. Maybe this could be why? </DIV><DIV>&nbsp;</DIV><DIV>If anyone has any knowledge I really need help. My boss is going out of town and I have to work in the office for a week alone, finishing up drawings on cad. I need this problem to be fixed or else I wont get these jobs done on time. Please let me know as soon as possible!</DIV>]]>
   <pubDate>Tue, 03 Aug 2010 18:00:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4121&amp;PID=10523&amp;title=please-help-autocad-fatal-error#10523</guid>
