  <title>CAD Forum discussion (EN) : 3dsMax-autocad question</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : 3ds Max, Maya, VRED : 3dsMax-autocad question]]></description>
  <pubDate>Thu, 08 Oct 2026 01:08:03 +0000</pubDate>
  <lastBuildDate>Sat, 21 Aug 2010 07:08:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4123</WebWizForums:feedURL>
   <title><![CDATA[3dsMax-autocad question : Thanks every one i got it.  ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10701&amp;title=3dsmaxautocad-question#10701</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=121328">heartscool</a><br /><strong>Subject:</strong> 4123<br /><strong>Posted:</strong> 21.Aug.2010 at 07:08<br /><br />Thanks every one i got it.]]>
   <pubDate>Sat, 21 Aug 2010 07:08:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10701&amp;title=3dsmaxautocad-question#10701</guid>
   <title><![CDATA[3dsMax-autocad question : You said you build your models...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10681&amp;title=3dsmaxautocad-question#10681</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4123<br /><strong>Posted:</strong> 20.Aug.2010 at 02:25<br /><br />You said you build your models in Autocad, but then you said you add your doors, windows, stairs, etc. in Max. Sounds to me like you build your models in Max. Anyway, what's the problem? What do you mean you can't put a window or door on your model? What's stopping you? Can you describe exactly what's happening?]]>
   <pubDate>Fri, 20 Aug 2010 02:25:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10681&amp;title=3dsmaxautocad-question#10681</guid>
   <title><![CDATA[3dsMax-autocad question : IM THE SAME WAY, I DO MY MODELS...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10680&amp;title=3dsmaxautocad-question#10680</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=102489">kalbou</a><br /><strong>Subject:</strong> 4123<br /><strong>Posted:</strong> 20.Aug.2010 at 01:10<br /><br />IM THE SAME WAY, I DO MY MODELS WITH AUTOCADD THEN IMPORT IT TO MAX TO RENDER AND PUT OTHER STUFF SUCH AS DOORS, WINDOWS, STAIRS AND ETC. BUT SOMEHOW I CANT PUT A WINDOW OR DOOR ON MY MODEL. ANYBODY CAN HELP ME?]]>
   <pubDate>Fri, 20 Aug 2010 01:10:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10680&amp;title=3dsmaxautocad-question#10680</guid>
   <title><![CDATA[3dsMax-autocad question : I&amp;#039;d rather model in Autocad...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10542&amp;title=3dsmaxautocad-question#10542</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=127569">Kellie Dobbie</a><br /><strong>Subject:</strong> 4123<br /><strong>Posted:</strong> 06.Aug.2010 at 04:10<br /><br />I'd rather model in Autocad (dwg format) and render in 3dsMax. After modeling in Autocad, you can import the file into 3dmax, create cameras,&nbsp;position&nbsp;lights, apply materials and render.]]>
   <pubDate>Fri, 06 Aug 2010 04:10:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10542&amp;title=3dsmaxautocad-question#10542</guid>
   <title><![CDATA[3dsMax-autocad question : Just Import your dwg into Max...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10527&amp;title=3dsmaxautocad-question#10527</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4123<br /><strong>Posted:</strong> 04.Aug.2010 at 08:04<br /><br />Just Import your dwg into Max and then start Extruding. <DIV>Do you have any experience working with 3DS Max?</DIV><DIV>Do you have any specific questions?</DIV>]]>
   <pubDate>Wed, 04 Aug 2010 08:04:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10527&amp;title=3dsmaxautocad-question#10527</guid>
   <title><![CDATA[3dsMax-autocad question : Hi guys any suggestion how to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10525&amp;title=3dsmaxautocad-question#10525</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=121328">heartscool</a><br /><strong>Subject:</strong> 4123<br /><strong>Posted:</strong> 03.Aug.2010 at 19:33<br /><br />Hi guys any suggestion how to build a house in max with DWG file ? thanks]]>
   <pubDate>Tue, 03 Aug 2010 19:33:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4123&amp;PID=10525&amp;title=3dsmaxautocad-question#10525</guid>
