  <title>CAD Forum discussion (EN) : pdf to dwg coverter</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : pdf to dwg coverter]]></description>
  <pubDate>Sat, 05 Sep 2026 10:49:32 +0000</pubDate>
  <lastBuildDate>Thu, 09 Sep 2010 21:29:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4217</WebWizForums:feedURL>
   <title><![CDATA[pdf to dwg coverter : Converting DWG paper space to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10970&amp;title=pdf-to-dwg-coverter#10970</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=128616">eirfro</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 09.Sep.2010 at 21:29<br /><br /><font size="2"><font face="Arial, Helvetica, sans-serif">Converting DWG paper space to PDF's has usally been rather simple, and upon opendning the pdf files generally there used to be no layers to turn off and on.<br><br>Now that I am running autocad 2011 Lt. I am finding that when a DWG is converted to pdf and opened in adobe reader there is the ability to turn on and off layers.&nbsp; Is there anyway to stop this from happening either in autocad or adobe acrobat 9.0? (the version on my computer)<br></font></font>]]>
   <pubDate>Thu, 09 Sep 2010 21:29:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10970&amp;title=pdf-to-dwg-coverter#10970</guid>
   <title><![CDATA[pdf to dwg coverter : I offen Use Illustrator open PDF...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10935&amp;title=pdf-to-dwg-coverter#10935</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=132777">autocadtk</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 08.Sep.2010 at 03:25<br /><br />I offen Use Illustrator open PDF and export to DFX format. <DIV>&nbsp;</DIV><DIV>But the PDF must be built by AutoCAD or some drawing software and not a picture!</DIV><DIV><a href="http://www.squidoo.com/pdf-to-dwg" target="_blank" rel="nofollow"><FONT color=#800080>http://www.squidoo.com/pdf-to-dwg</FONT></A>&nbsp; there are three way to convert the PDF to DWG</DIV><span style="font-size:10px"><br /><br />Edited by autocadtk - 03.Dec.2010 at 04:47</span>]]>
   <pubDate>Wed, 08 Sep 2010 03:25:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10935&amp;title=pdf-to-dwg-coverter#10935</guid>
   <title><![CDATA[pdf to dwg coverter : Hello,  I can confirm a fully...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10912&amp;title=pdf-to-dwg-coverter#10912</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=132557">VIT66</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 07.Sep.2010 at 00:38<br /><br />Hello,<DIV>&nbsp;</DIV><DIV>I can confirm a fully functional pdf2cad&nbsp;30 days trial version is available from&nbsp;<a href="http://www.pdf2cad.com" target="_blank" rel="nofollow">http://www.pdf2cad.com</a>. </DIV><DIV>&nbsp;</DIV><DIV>If you do not have the time to test pdf2cad, you can upload a test file and Visual Integrity will convert it for you.</DIV><DIV>&nbsp;</DIV><DIV>If you think pdf2cad does not a great job, please contact us at support-at-pdf2cad.com and let us know why you are not satisfied with the conversion results. We will be more than happy to help you fine tune conversion options to reach your expectations.</DIV><DIV>&nbsp;</DIV><DIV>Patrick</DIV>]]>
   <pubDate>Tue, 07 Sep 2010 00:38:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10912&amp;title=pdf-to-dwg-coverter#10912</guid>
   <title><![CDATA[pdf to dwg coverter :    BTPDesigns wrote:HelloOpen...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10790&amp;title=pdf-to-dwg-coverter#10790</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=130876">athurart09</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 27.Aug.2010 at 11:32<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by BTPDesigns" alt="Originally posted by BTPDesigns" style="vertical-align: text-bottom;" /> <strong>BTPDesigns wrote:</strong><br /><br />Hello<br><br>Open the PDF in Adobe Illustrator. Then export the drawing to AutoCAD on a 8 bit setting. Open the drawing and use scale command to scale the drawing according to the pdf drawing scale. If there isn't a drawing scale then use a dimension on the drawing. Good Luck!!!</td></tr></table>Thank you for the information.]]>
   <pubDate>Fri, 27 Aug 2010 11:32:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10790&amp;title=pdf-to-dwg-coverter#10790</guid>
   <title><![CDATA[pdf to dwg coverter : I USE PRINT2CAD CONVERSTION SOFTWARE....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10767&amp;title=pdf-to-dwg-coverter#10767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=123438">David Tsosie</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 25.Aug.2010 at 16:51<br /><br />I USE PRINT2CAD CONVERSTION SOFTWARE.&nbsp; $149 SOFTWARE THAT TAKES CARE OF VECTOR PDFS NICELY.&nbsp; RASTER PDFS PRETTY MUCH NEED TO BE REDRAWN AFTER CONVERSION.]]>
   <pubDate>Wed, 25 Aug 2010 16:51:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10767&amp;title=pdf-to-dwg-coverter#10767</guid>
   <title><![CDATA[pdf to dwg coverter : You could also try www.pdf2cad.com.  Not...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10764&amp;title=pdf-to-dwg-coverter#10764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=82126">Tankman</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 25.Aug.2010 at 15:43<br /><br />You could also try <a href="http://www.pdf2cad.com" target="_blank" rel="nofollow">www.pdf2cad.com</A>.<DIV>&nbsp;</DIV><DIV>Not a great job but, it will get you started.</DIV><DIV>&nbsp;</DIV><DIV>I believe there is a free trial download to try it out.</DIV><DIV>I use pdf2cad on occasion.</DIV><DIV>&nbsp;</DIV><DIV>Good luck!&nbsp; <img src="http://www.cadforum.cz/forum_en/smileys/smiley2.gif" height="17" width="17" border="0" align="absmiddle" alt="Wink" /></DIV>]]>
   <pubDate>Wed, 25 Aug 2010 15:43:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10764&amp;title=pdf-to-dwg-coverter#10764</guid>
   <title><![CDATA[pdf to dwg coverter : Yes, like Tankman said. You can...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10748&amp;title=pdf-to-dwg-coverter#10748</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=129642">BTPDesigns</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 25.Aug.2010 at 02:30<br /><br />Yes, like Tankman said. You can modify the drawings. Yet the line weights and layers may not be the same. That depends if they plotted with it. If they flatten the pdf. Then layers won't be available.]]>
   <pubDate>Wed, 25 Aug 2010 02:30:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10748&amp;title=pdf-to-dwg-coverter#10748</guid>
   <title><![CDATA[pdf to dwg coverter : You&amp;#039;ll re-work the AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10735&amp;title=pdf-to-dwg-coverter#10735</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=82126">Tankman</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 24.Aug.2010 at 15:36<br /><br />You'll re-work the AutoCAD drawing and make revisions and/or changes there. <DIV>&nbsp;</DIV><DIV>You could open the *.pdf in Adobe Pro and do a little *.pdf cropping there, save as a *.pdf then open in Illustrator.</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><span style="font-size:10px"><br /><br />Edited by Tankman - 24.Aug.2010 at 15:37</span>]]>
   <pubDate>Tue, 24 Aug 2010 15:36:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10735&amp;title=pdf-to-dwg-coverter#10735</guid>
   <title><![CDATA[pdf to dwg coverter : thanks for the response...but...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10726&amp;title=pdf-to-dwg-coverter#10726</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=130167">rjnshdass</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 24.Aug.2010 at 06:08<br /><br />thanks for the response...but one more question...when the pdf drawing is opened in illustrator will we be able to edit the pdf drawing same when exported to autocad.....thanks<br><br>]]>
   <pubDate>Tue, 24 Aug 2010 06:08:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10726&amp;title=pdf-to-dwg-coverter#10726</guid>
   <title><![CDATA[pdf to dwg coverter : HelloOpen the PDF in Adobe Illustrator....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10725&amp;title=pdf-to-dwg-coverter#10725</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=129642">BTPDesigns</a><br /><strong>Subject:</strong> 4217<br /><strong>Posted:</strong> 24.Aug.2010 at 06:00<br /><br />Hello<br><br>Open the PDF in Adobe Illustrator. Then export the drawing to AutoCAD on a 8 bit setting. Open the drawing and use scale command to scale the drawing according to the pdf drawing scale. If there isn't a drawing scale then use a dimension on the drawing. Good Luck!!!]]>
   <pubDate>Tue, 24 Aug 2010 06:00:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4217&amp;PID=10725&amp;title=pdf-to-dwg-coverter#10725</guid>
