  <title>CAD Forum discussion (EN) : By Layer Problem</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : By Layer Problem]]></description>
  <pubDate>Sat, 05 Sep 2026 03:11:46 +0000</pubDate>
  <lastBuildDate>Thu, 26 Aug 2010 18:41:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4247</WebWizForums:feedURL>
   <title><![CDATA[By Layer Problem : Try using the command &amp;#034;change&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4247&amp;PID=10786&amp;title=by-layer-problem#10786</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 4247<br /><strong>Posted:</strong> 26.Aug.2010 at 18:41<br /><br />Try using the command "change" or "chprop" on the command line.]]>
   <pubDate>Thu, 26 Aug 2010 18:41:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4247&amp;PID=10786&amp;title=by-layer-problem#10786</guid>
   <title><![CDATA[By Layer Problem : I&amp;#039;m working on a drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4247&amp;PID=10782&amp;title=by-layer-problem#10782</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=130669">domsib</a><br /><strong>Subject:</strong> 4247<br /><strong>Posted:</strong> 26.Aug.2010 at 11:21<br /><br />I'm working on a drawing where all items are on layers set to colour 8. However the majority have had the colours changed in the object colour dropdown box. I have exactly 23676 items to now change back to bylayer so that all colours show as colour 8. The problem I have is when I 'select all' the object colour dropdown shows they are all by layer and therefore wont let me change them all at once. I have even tried changing them to red, yellow etc just to see if they change but they dont. I can however select a small group and then it will let me change these all together.<DIV>Is there any solution to changing all these at once because going through the drawing highlighting small areas and changing them is going to take me an eternity and I have four drawings the same. </DIV><DIV>&nbsp;</DIV><DIV>Thanks</DIV>]]>
   <pubDate>Thu, 26 Aug 2010 11:21:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4247&amp;PID=10782&amp;title=by-layer-problem#10782</guid>
