  <title>CAD Forum discussion (EN) : Error message</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Error message]]></description>
  <pubDate>Wed, 21 Oct 2026 14:01:26 +0000</pubDate>
  <lastBuildDate>Fri, 27 Aug 2010 16:23:47 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4248</WebWizForums:feedURL>
   <title><![CDATA[Error message : Rather than wasting a lot of time...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10791&amp;title=error-message#10791</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4248<br /><strong>Posted:</strong> 27.Aug.2010 at 16:23<br /><br />Rather than wasting a lot of time with this corrupt file, just contact the person who sent it to you and have them Purge and Audit the file on their end and then send you a new, clean file.]]>
   <pubDate>Fri, 27 Aug 2010 16:23:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10791&amp;title=error-message#10791</guid>
   <title><![CDATA[Error message : Thanks for reply.   When I use...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10789&amp;title=error-message#10789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=130667">Georgina Molloy</a><br /><strong>Subject:</strong> 4248<br /><strong>Posted:</strong> 27.Aug.2010 at 09:42<br /><br /><DIV>Thanks for reply. </DIV><DIV>&nbsp;</DIV><DIV>When I use the recover command an 'edit' text box comes up. </DIV><DIV>In the box it says </DIV><DIV>&nbsp;</DIV><DIV>'Reading handle? Object type? Error 53 (EfilerError) Object discarded'. </DIV><DIV>&nbsp;</DIV><DIV>It asks me to 'press enter to continue' but pressing enter does not work.</DIV>]]>
   <pubDate>Fri, 27 Aug 2010 09:42:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10789&amp;title=error-message#10789</guid>
   <title><![CDATA[Error message : Try running the RECOVER command....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10787&amp;title=error-message#10787</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4248<br /><strong>Posted:</strong> 27.Aug.2010 at 03:06<br /><br />Try running the <strong>RECOVER</strong> command.]]>
   <pubDate>Fri, 27 Aug 2010 03:06:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10787&amp;title=error-message#10787</guid>
   <title><![CDATA[Error message : Hi,  I am getting the following...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10784&amp;title=error-message#10784</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=130667">Georgina Molloy</a><br /><strong>Subject:</strong> 4248<br /><strong>Posted:</strong> 26.Aug.2010 at 16:32<br /><br />Hi,<DIV>&nbsp;</DIV><DIV>I am getting the following error message when I try to open a file emailed to me. </DIV><DIV>&nbsp;</DIV><DIV>INTERNAL ERROR: <a href="mailto:!dbvport.cpp@2645:eFilerError" target="_blank" rel="nofollow">!dbvport.cpp@2645:eFilerError</A></DIV><DIV>&nbsp;</DIV><DIV>Does anyone know why this is and how I can fix the problem?</DIV><DIV>&nbsp;</DIV><DIV>Thanks.</DIV>]]>
   <pubDate>Thu, 26 Aug 2010 16:32:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4248&amp;PID=10784&amp;title=error-message#10784</guid>
