  <title>CAD Forum discussion (EN) : block not eraseable</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : block not eraseable]]></description>
  <pubDate>Thu, 29 Oct 2026 23:56:38 +0000</pubDate>
  <lastBuildDate>Wed, 15 Sep 2010 02:33:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4313</WebWizForums:feedURL>
   <title><![CDATA[block not eraseable :   jmattingly wrote:When you create...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11034&amp;title=block-not-eraseable#11034</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 15.Sep.2010 at 02:33<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by jmattingly" alt="Originally posted by jmattingly" style="vertical-align: text-bottom;" /> <strong>jmattingly wrote:</strong><br /><br />When you create the block, there is a setting, so it will not explode.&nbsp;</td></tr></table> <DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>But all that does is makes it unexplodable. It's still editable. And all you have to do is open the block in the editor, BEDIT, and change it back to "Allow Exploding" and then it&nbsp;can be exploded again. </DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>There really is no way to protect drawings. If someone comes up with a way to lock a drawing, someone else will come up with a way to unlock it. That's just the way it goes.</DIV><DIV>&nbsp;</DIV><DIV>Just keep good records of what you sent, when you sent it and who you sent it to. Sending zip files via email is a great way to keep track of where your drawings are going. Also,&nbsp;include a disclaimer with the drawings which&nbsp;states that any changes made to them without your consent will violate whatever contract you have and void any guarantees or warantees, expressed or implied, contained within the drawings. Have your&nbsp;lawyer write something up.</DIV><DIV>&nbsp;</DIV><DIV>But, if you are contracted to provide dwg's to your client, that's what you have to provide. You should not be trying to lock your drawings.</DIV>]]>
   <pubDate>Wed, 15 Sep 2010 02:33:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11034&amp;title=block-not-eraseable#11034</guid>
   <title><![CDATA[block not eraseable : When you create the block, there...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11033&amp;title=block-not-eraseable#11033</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=69411">jmattingly</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 14.Sep.2010 at 23:48<br /><br /><P>When you create the block, there is a setting, so it will not explode.&nbsp; Just click on the box in your block editor.&nbsp; Hope this helps.</P><DIV>&nbsp;</DIV><DIV>J</DIV>]]>
   <pubDate>Tue, 14 Sep 2010 23:48:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11033&amp;title=block-not-eraseable#11033</guid>
   <title><![CDATA[block not eraseable :      Normal   0       ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11007&amp;title=block-not-eraseable#11007</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=133879">haithamsitto</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 14.Sep.2010 at 04:54<br /><br /><!--&#091;if gte mso 9&#093;> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:TrackMoves/>  <w:Trackatting/>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixedC&#111;ntent>false</w:IgnoreMixedC&#111;ntent>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:D&#111;notPromoteQF/>  <w:LidThemeOther>EN-US</w:LidThemeOther>  <w:LidThemeAsian>X-NONE</w:LidThemeAsian>  <w:LidThemeComplex>AR-SA</w:LidThemeComplex>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>   <w:SplitPgBreakAndark/>   <w:D&#111;ntVertAlignCellWithSp/>   <w:D&#111;ntBreakC&#111;nstrainedForcedTables/>   <w:D&#111;ntVertAlignInTxbx/>   <w:Word11KerningPairs/>   <w:CachedColBalance/>  </w:Compatibility>  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>  <m:mathPr>   <m:mathFont m:val="Cambria Math"/>   <m:brkBin m:val="before"/>   <m:brkBinSub m:val="--"/>   <m:smallFrac m:val="off"/>   <m:dispDef/>   <m:lMargin m:val="0"/>   <m:rMargin m:val="0"/>   <m:defJc m:val="centerGroup"/>   <m:wrapIndent m:val="1440"/>   <m:intLim m:val="subSup"/>   <m:naryLim m:val="undOvr"/>  </m:mathPr></w:Word><!&#091;endif&#093;--><!--&#091;if gte mso 9&#093;> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"    DefSemi="true" DefQat="false" DefPriority="99"    LatentStyleCount="267">  <w:LsdExcepti&#111;n Locked="false" Priority="0" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Normal"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="ing 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 9"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="toc 9"/>  <w:LsdExcepti&#111;n Locked="false" Priority="35" Qat="true" Name="capti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Priority="10" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Title"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Name="Default Paragraph Font"/>  <w:LsdExcepti&#111;n Locked="false" Priority="11" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Subtitle"/>  <w:LsdExcepti&#111;n Locked="false" Priority="22" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Str&#111;ng"/>  <w:LsdExcepti&#111;n Locked="false" Priority="20" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="59" Semi="false"     UnhideWhenUsed="false" Name="Table Grid"/>  <w:LsdExcepti&#111;n Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="No Spacing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" UnhideWhenUsed="false" Name="Revisi&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Priority="34" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="List Paragraph"/>  <w:LsdExcepti&#111;n Locked="false" Priority="29" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="30" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Intense Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Semi="false"     UnhideWhenUsed="false" Name="Light Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Semi="false"     UnhideWhenUsed="false" Name="Light List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Semi="false"     UnhideWhenUsed="false" Name="Light Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Semi="false"     UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Semi="false"     UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Semi="false"     UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Semi="false"     UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Semi="false"     UnhideWhenUsed="false" Name="Dark List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Semi="false"     UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Semi="false"     UnhideWhenUsed="false" Name="Colorful List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Semi="false"     UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="19" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Subtle Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="21" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Intense Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="31" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Subtle Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="32" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Intense Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="33" Semi="false"     UnhideWhenUsed="false" Qat="true" Name="Book Title"/>  <w:LsdExcepti&#111;n Locked="false" Priority="37" Name="Bibliography"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Qat="true" Name="TOC ing"/> </w:LatentStyles><!&#091;endif&#093;--><!--&#091;if gte mso 10&#093;> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-qformat:yes;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0in;	line-height:115%;	mso-pagination:widow-orphan;	font-size:11.0pt;	font-family:"Calibri","sans-serif";	mso-ascii-font-family:Calibri;	mso-ascii-theme-font:minor-latin;	mso-fareast-font-family:"Times New Roman";	mso-fareast-theme-font:minor-fareast;	mso-hansi-font-family:Calibri;	mso-hansi-theme-font:minor-latin;}<!&#091;endif&#093;--><p ="Ms&#111;normal">I have never run into a situation where a file provided tome was not changeable.<span style="">&nbsp; </span>Even as areference, the block has to be available to reference. If you have a concernabout your drawing not being changed, don’t share it in a cad format, send apdf file.<span style="">&nbsp; </span>Even those can now bevectorized and changed as needed if your know how to do it.<span style="">&nbsp; </span>We do this all day long because the clientsprovide us with paper line drawings.</p>]]>
   <pubDate>Tue, 14 Sep 2010 04:54:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11007&amp;title=block-not-eraseable#11007</guid>
   <title><![CDATA[block not eraseable : There is software out there that...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11006&amp;title=block-not-eraseable#11006</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 14.Sep.2010 at 02:45<br /><br />There is software out there that will supposedly lock a drawing, making it uneditable. You might want to check out that option. The program I'm referring to is called CadLock. Google it for more information.]]>
   <pubDate>Tue, 14 Sep 2010 02:45:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=11006&amp;title=block-not-eraseable#11006</guid>
   <title><![CDATA[block not eraseable : to enshure that no one change...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10996&amp;title=block-not-eraseable#10996</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55518">reyad102</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 13.Sep.2010 at 18:21<br /><br />to enshure that no one change my dwg.]]>
   <pubDate>Mon, 13 Sep 2010 18:21:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10996&amp;title=block-not-eraseable#10996</guid>
   <title><![CDATA[block not eraseable : tell me why u want to protect...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10988&amp;title=block-not-eraseable#10988</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55299">deepu</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 13.Sep.2010 at 09:59<br /><br />tell me why u want to protect like this. if u want to protect your file u can use password.]]>
   <pubDate>Mon, 13 Sep 2010 09:59:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10988&amp;title=block-not-eraseable#10988</guid>
   <title><![CDATA[block not eraseable : well try to insert it as reference....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10979&amp;title=block-not-eraseable#10979</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 10.Sep.2010 at 22:11<br /><br />well try to insert it as reference. From my experience I know that many people still do not know how to work with references and they are trying to delete such objects with no luck :))]]>
   <pubDate>Fri, 10 Sep 2010 22:11:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10979&amp;title=block-not-eraseable#10979</guid>
   <title><![CDATA[block not eraseable : You want to make it so that it...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10924&amp;title=block-not-eraseable#10924</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 07.Sep.2010 at 15:51<br /><br />You want to make it so that it can <b>NEVER</b> be erased??? Sorry, I don't think that's possible, and, I don't even know why you would want to do that?]]>
   <pubDate>Tue, 07 Sep 2010 15:51:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10924&amp;title=block-not-eraseable#10924</guid>
   <title><![CDATA[block not eraseable : but you can unlock that layer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10923&amp;title=block-not-eraseable#10923</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55518">reyad102</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 07.Sep.2010 at 15:19<br /><br />but you can unlock that layer and erase it....I would like it not eraseable???]]>
   <pubDate>Tue, 07 Sep 2010 15:19:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10923&amp;title=block-not-eraseable#10923</guid>
   <title><![CDATA[block not eraseable : Put it on a locked layer. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10901&amp;title=block-not-eraseable#10901</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4313<br /><strong>Posted:</strong> 05.Sep.2010 at 17:38<br /><br />Put it on a locked layer.]]>
   <pubDate>Sun, 05 Sep 2010 17:38:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4313&amp;PID=10901&amp;title=block-not-eraseable#10901</guid>
