  <title>CAD Forum discussion (EN) : Question about data extraction</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Question about data extraction]]></description>
  <pubDate>Sat, 05 Sep 2026 03:01:57 +0000</pubDate>
  <lastBuildDate>Fri, 24 Sep 2010 20:01:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4348</WebWizForums:feedURL>
   <title><![CDATA[Question about data extraction : If you use a different hatch for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4348&amp;PID=11200&amp;title=question-about-data-extraction#11200</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=37715">mjlsr1</a><br /><strong>Subject:</strong> 4348<br /><strong>Posted:</strong> 24.Sep.2010 at 20:01<br /><br />If you use a different hatch for each location you could extract using the pattern name and geometry for your info.&nbsp; If you need to use the same hatch in multiple areas then add a different color to the hatch so you can break up the areas.&nbsp; Hope this helps.]]>
   <pubDate>Fri, 24 Sep 2010 20:01:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4348&amp;PID=11200&amp;title=question-about-data-extraction#11200</guid>
   <title><![CDATA[Question about data extraction : I have a question about data extraction...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4348&amp;PID=11021&amp;title=question-about-data-extraction#11021</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=133941">Andecal23</a><br /><strong>Subject:</strong> 4348<br /><strong>Posted:</strong> 14.Sep.2010 at 12:59<br /><br />I have a question about data extraction in AutoCAD Architectural 2009.<br><br>I have an original drawing of a floorplan of a building. On this drawing I draw polylines with hatches above the original drawing to calculate areas and lengths of the walls.<br><br>With data extraction (table) I can get all the values of the polylines and hatches (Length and Area) but is there a possibility to give each line of the table automatically a seperate number and put these numbers also at the polyline or in the hatch so I can see where which value is located when I plot these drawings.<br>]]>
   <pubDate>Tue, 14 Sep 2010 12:59:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4348&amp;PID=11021&amp;title=question-about-data-extraction#11021</guid>
