  <title>CAD Forum discussion (EN) : assign layer to command</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : assign layer to command]]></description>
  <pubDate>Mon, 19 Oct 2026 23:30:21 +0000</pubDate>
  <lastBuildDate>Fri, 01 Oct 2010 15:54:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4534</WebWizForums:feedURL>
   <title><![CDATA[assign layer to command : Yes, FLay.tab is loaded automatically...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11340&amp;title=assign-layer-to-command#11340</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 15:54<br /><br />Yes, FLay.tab <EM>is</EM> loaded automatically on load of the application. But it must be located in the AutoCAD search path (otherwise FLay displays a warning "FLay.tab not found").]]>
   <pubDate>Fri, 01 Oct 2010 15:54:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11340&amp;title=assign-layer-to-command#11340</guid>
   <title><![CDATA[assign layer to command : ok, made it working.The file vlx...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11337&amp;title=assign-layer-to-command#11337</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 14:48<br /><br /><p>ok, made it working.</p><p>The file vlx was loaded, but I had to manualy load the fly.tab using the fly! command as described in fly.txt. (I thought fly.tab would be loaded automatically as it is at the same loacation as the vlx)</p><p>Anyway, let me thank you again, this will save me "few" clicks ;)</p>]]>
   <pubDate>Fri, 01 Oct 2010 14:48:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11337&amp;title=assign-layer-to-command#11337</guid>
   <title><![CDATA[assign layer to command : Well, AutoCAD 2006 is rather old...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11336&amp;title=assign-layer-to-command#11336</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 13:19<br /><br />Well, AutoCAD 2006 is rather old and FLay was not tested in it but I think it should work. Please make sure that the VLX file is loaded (APPLOAD) and that the FLay.TAB file is located in AutoCAD support path.<DIV>&nbsp;</DIV><DIV>Are there any FLay messages showing on your AutoCAD command line?</DIV>]]>
   <pubDate>Fri, 01 Oct 2010 13:19:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11336&amp;title=assign-layer-to-command#11336</guid>
   <title><![CDATA[assign layer to command : actually,. I&amp;#039;m having difficulty...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11334&amp;title=assign-layer-to-command#11334</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 12:21<br /><br /><p>actually,. I'm having difficulty to run the fly reactor. It doesn't seem to be working. I tried the samples as well as to add my lines, loaded the vlx, even restarted autocad but it is not working somehow. Any idea what can be the issue?</p><p>thank you</p><p>ps: I'm using Acad 2006 on Win XP</p>]]>
   <pubDate>Fri, 01 Oct 2010 12:21:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11334&amp;title=assign-layer-to-command#11334</guid>
   <title><![CDATA[assign layer to command : Vladimir,  thank you very much...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11332&amp;title=assign-layer-to-command#11332</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 11:57<br /><br /><p>Vladimir,</p><p><br></p><p>thank you very much for help .. much appreciated</p>]]>
   <pubDate>Fri, 01 Oct 2010 11:57:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11332&amp;title=assign-layer-to-command#11332</guid>
   <title><![CDATA[assign layer to command : There are several ways to do t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11331&amp;title=assign-layer-to-command#11331</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 11:47<br /><br />There are several ways to do this.<DIV>&nbsp;</DIV><DIV>See:</DIV><DIV><a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6433" target="_blank">http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6433</A></DIV><DIV><a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5131" target="_blank">http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5131</A></DIV>]]>
   <pubDate>Fri, 01 Oct 2010 11:47:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11331&amp;title=assign-layer-to-command#11331</guid>
   <title><![CDATA[assign layer to command : Hi all,  I&amp;#039;m wondering...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11330&amp;title=assign-layer-to-command#11330</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 4534<br /><strong>Posted:</strong> 01.Oct.2010 at 11:35<br /><br /><p>Hi all,</p><p>I'm wondering if anyone knows how could a layer be assigned to a command, e.g. command cloud would be assigned to layer with the same name. (We are using CADS software with ACAD 2006 and the CADS commands have layers assigned to commands, for example any dimension command has layer DIM assigned to it).</p><p><br></p><p>Thank you very much</p>]]>
   <pubDate>Fri, 01 Oct 2010 11:35:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4534&amp;PID=11330&amp;title=assign-layer-to-command#11330</guid>
