  <title>CAD Forum discussion (EN) : Layout sizing questions</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Layout sizing questions]]></description>
  <pubDate>Sat, 24 Oct 2026 16:57:19 +0000</pubDate>
  <lastBuildDate>Fri, 08 Oct 2010 15:28:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4574</WebWizForums:feedURL>
   <title><![CDATA[Layout sizing questions :   Cheers DJP will take note...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11437&amp;title=layout-sizing-questions#11437</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=59191">scottie2065</a><br /><strong>Subject:</strong> 4574<br /><strong>Posted:</strong> 08.Oct.2010 at 15:28<br /><br />Cheers DJP will take note of that<br>i knew about the ctrl+tab<br>but the rest will be useful cheers<br><span style="font-size:10px"><br /><br />Edited by scottie2065 - 08.Oct.2010 at 15:29</span>]]>
   <pubDate>Fri, 08 Oct 2010 15:28:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11437&amp;title=layout-sizing-questions#11437</guid>
   <title><![CDATA[Layout sizing questions : Thanks for that, i used the page...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11436&amp;title=layout-sizing-questions#11436</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=135003">djp6</a><br /><strong>Subject:</strong> 4574<br /><strong>Posted:</strong> 08.Oct.2010 at 15:14<br /><br />Thanks for that, i used the page setup manager to change the paper size which worked OK, whilst researching i've been told about these shortcuts, you might find them useful.<br><br>MS &amp; PS will swap between model an paper space.<br><br>Ctrl + page up or page down will swap between layout tabs.<br><br>Ctrl + tab swaps between open drawings.<br><br>Ctrl+R lets you cycle through active viewports.<br>]]>
   <pubDate>Fri, 08 Oct 2010 15:14:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11436&amp;title=layout-sizing-questions#11436</guid>
   <title><![CDATA[Layout sizing questions : to change paper size you right...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11416&amp;title=layout-sizing-questions#11416</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=59191">scottie2065</a><br /><strong>Subject:</strong> 4574<br /><strong>Posted:</strong> 07.Oct.2010 at 12:24<br /><br />to change paper size you right click on the layout tab and goto "page setup manager" and select your layout and hit modify<br>then you can change you papersize from the dropdown menu<br>i dont know any commands to alternate between tabs<br>]]>
   <pubDate>Thu, 07 Oct 2010 12:24:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11416&amp;title=layout-sizing-questions#11416</guid>
   <title><![CDATA[Layout sizing questions :      Normal   0       ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11412&amp;title=layout-sizing-questions#11412</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=135003">djp6</a><br /><strong>Subject:</strong> 4574<br /><strong>Posted:</strong> 07.Oct.2010 at 10:57<br /><br /><!--&#091;if gte mso 9&#093;> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixedC&#111;ntent>false</w:IgnoreMixedC&#111;ntent>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>  </w:Compatibility>  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:Word><!&#091;endif&#093;--><!--&#091;if gte mso 9&#093;> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles><!&#091;endif&#093;--><!--&#091;if gte mso 10&#093;> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-parent:"";	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;	mso-para-margin:0cm;	mso-para-margin-bottom:.0001pt;	mso-pagination:widow-orphan;	font-size:10.0pt;	font-family:"Times New Roman";	mso-ansi-language:#0400;	mso-fareast-language:#0400;	mso-bidi-language:#0400;}<!&#091;endif&#093;--><p ="Ms&#111;normal">Hi</p><p ="Ms&#111;normal">Using 2008.</p><p ="Ms&#111;normal">How do you change white paper size or reduce to fit the modelitems, border, titleblock, viewports, etc. i.e. the border and viewports etcare larger then the white space, how do I get it to fit, and what are theshortcuts for the process. </p><p ="Ms&#111;normal">Also </p><p ="Ms&#111;normal">What’s the keyboard short cut to swap between model and paperspace and to swap between various layout tabs and model tab.</p><p ="Ms&#111;normal">Any help would be much appreciated.</p><p ="Ms&#111;normal">Cheers</p>]]>
   <pubDate>Thu, 07 Oct 2010 10:57:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4574&amp;PID=11412&amp;title=layout-sizing-questions#11412</guid>
