  <title>CAD Forum discussion (EN) : help with the project</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : help with the project]]></description>
  <pubDate>Mon, 07 Sep 2026 10:21:18 +0000</pubDate>
  <lastBuildDate>Fri, 26 Nov 2010 11:06:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4711</WebWizForums:feedURL>
   <title><![CDATA[help with the project : Hi there,im not sure u quite under...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4711&amp;PID=11962&amp;title=help-with-the-project#11962</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=151088">HenryT</a><br /><strong>Subject:</strong> 4711<br /><strong>Posted:</strong> 26.Nov.2010 at 11:06<br /><br />Hi there,im not sure u quite under stand your problem but&nbsp; i rate it comes&nbsp; down to basics,first of all you are going to need dimensions and you say you must draw the car inside and out,so i rate you must get someone who has a very basic car,get a measuring tape.then you measure and draw as you go on.if you want to draw a 3d model its going to be easier to first draw 2d drawings of the car and afterrwards use those drawings to draw up your 3d model. good luck]]>
   <pubDate>Fri, 26 Nov 2010 11:06:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4711&amp;PID=11962&amp;title=help-with-the-project#11962</guid>
   <title><![CDATA[help with the project : hello every one im new in this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4711&amp;PID=11708&amp;title=help-with-the-project#11708</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=145541">maria syed</a><br /><strong>Subject:</strong> 4711<br /><strong>Posted:</strong> 04.Nov.2010 at 16:18<br /><br />hello every one im new in this forum.actually i got a projetc for autocad that i have to design a car.interior exterior everything. im new with the auto cad so i actualy am confused from wwhere to start. plz help me out by telling me steps of wat to do. and wat car should i choose for this project. waiting for help asap<br>regards<br>]]>
   <pubDate>Thu, 04 Nov 2010 16:18:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4711&amp;PID=11708&amp;title=help-with-the-project#11708</guid>
