  <title>CAD Forum discussion (EN) : Cannot open dwg file</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Cannot open dwg file]]></description>
  <pubDate>Sat, 05 Sep 2026 22:52:20 +0000</pubDate>
  <lastBuildDate>Tue, 09 Nov 2010 07:37:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4719</WebWizForums:feedURL>
   <title><![CDATA[Cannot open dwg file : recover is the basic..option ...its...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11756&amp;title=cannot-open-dwg-file#11756</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55299">deepu</a><br /><strong>Subject:</strong> 4719<br /><strong>Posted:</strong> 09.Nov.2010 at 07:37<br /><br />recover is the basic..option ...its not working with this few files...]]>
   <pubDate>Tue, 09 Nov 2010 07:37:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11756&amp;title=cannot-open-dwg-file#11756</guid>
   <title><![CDATA[Cannot open dwg file : this is 2000 format..only this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11754&amp;title=cannot-open-dwg-file#11754</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55299">deepu</a><br /><strong>Subject:</strong> 4719<br /><strong>Posted:</strong> 09.Nov.2010 at 07:34<br /><br />this is 2000 format..only this few files have problem..i am using 2007.]]>
   <pubDate>Tue, 09 Nov 2010 07:34:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11754&amp;title=cannot-open-dwg-file#11754</guid>
   <title><![CDATA[Cannot open dwg file : Try opening them using the RECOVER...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11751&amp;title=cannot-open-dwg-file#11751</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4719<br /><strong>Posted:</strong> 09.Nov.2010 at 02:16<br /><br />Try opening them using the <b>RECOVER</b> command.]]>
   <pubDate>Tue, 09 Nov 2010 02:16:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11751&amp;title=cannot-open-dwg-file#11751</guid>
   <title><![CDATA[Cannot open dwg file :   See TIP 868 below maybe you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11727&amp;title=cannot-open-dwg-file#11727</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 4719<br /><strong>Posted:</strong> 07.Nov.2010 at 14:38<br /><br /><div><br></div><div>&nbsp;See TIP 868 below maybe you have drawing with a newer version of CAD.</div><div><br></div><div>&nbsp;Or maybe it is not drawing by any Autodesk product.</div>]]>
   <pubDate>Sun, 07 Nov 2010 14:38:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11727&amp;title=cannot-open-dwg-file#11727</guid>
   <title><![CDATA[Cannot open dwg file :  hai ,now i am facing a major...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11720&amp;title=cannot-open-dwg-file#11720</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55299">deepu</a><br /><strong>Subject:</strong> 4719<br /><strong>Posted:</strong> 06.Nov.2010 at 06:23<br /><br /><SPAN style="FONT-FAMILY: 'Calibri','sans-serif'; FONT-SIZE: 11pt; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: Arial; mso-bidi-theme-font: minor-bidi; mso-ansi-: EN-US; mso-fareast-: EN-US; mso-bidi-: AR-SA"><FONT color=#000000><DIV>hai ,now i am facing a major error with cad 2007-i cannot open files ,i am getting this error&nbsp; <strong><U><FONT color=#0000ff>FATAL ERROR: Unhandled e06d7363h Exception at 7c812afbh </FONT></U></strong></DIV><DIV><FONT color=#330033>but the same files i can open with DWG TrueView 2008 .any idea about this..</FONT></DIV><DIV><FONT color=#330033>help me if you know about this...</FONT></DIV><DIV><FONT color=#330033>thank you</FONT></DIV></FONT></SPAN>]]>
   <pubDate>Sat, 06 Nov 2010 06:23:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4719&amp;PID=11720&amp;title=cannot-open-dwg-file#11720</guid>
