  <title>CAD Forum discussion (EN) : System Variable Settings</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : System Variable Settings]]></description>
  <pubDate>Fri, 12 Jun 2026 23:55:41 +0000</pubDate>
  <lastBuildDate>Thu, 11 Nov 2010 10:41:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4722</WebWizForums:feedURL>
   <title><![CDATA[System Variable Settings : System variable setting is also...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11809&amp;title=system-variable-settings#11809</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=147291">honeycrippen12</a><br /><strong>Subject:</strong> 4722<br /><strong>Posted:</strong> 11.Nov.2010 at 10:41<br /><br />System variable setting is also one of big issue,well u all have discussed well about it and I really appreciate with that.<br><br><br><br>Thanks for sharing it<br><a href="http://www.newt&#111;nit.co.uk/products/disaster-recovery" target="_blank" rel="nofollow">Disaster Recovery Plan</a> <br>]]>
   <pubDate>Thu, 11 Nov 2010 10:41:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11809&amp;title=system-variable-settings#11809</guid>
   <title><![CDATA[System Variable Settings : Your user profile is being probably...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11758&amp;title=system-variable-settings#11758</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 4722<br /><strong>Posted:</strong> 09.Nov.2010 at 08:58<br /><br />Your user profile is being probably reset on each AutoCAD launch (using some custom mechanism) or you have no read/write access to your profile.]]>
   <pubDate>Tue, 09 Nov 2010 08:58:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11758&amp;title=system-variable-settings#11758</guid>
   <title><![CDATA[System Variable Settings :  CAD64 Thanks for your reply,I&amp;#039;m...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11757&amp;title=system-variable-settings#11757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=146110">Muqq</a><br /><strong>Subject:</strong> 4722<br /><strong>Posted:</strong> 09.Nov.2010 at 08:49<br /><br />CAD64 Thanks for your reply,<br><br>I'm not using any lisp files and 3d add-on program,<br><br>please give me solution waiting for that,<br><br>thanking you,<br><br><span style="font-size:10px"><br /><br />Edited by Muqq - 09.Nov.2010 at 08:49</span>]]>
   <pubDate>Tue, 09 Nov 2010 08:49:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11757&amp;title=system-variable-settings#11757</guid>
   <title><![CDATA[System Variable Settings : Are you using any custom lisp...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11753&amp;title=system-variable-settings#11753</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4722<br /><strong>Posted:</strong> 09.Nov.2010 at 02:22<br /><br />Are you using any custom lisp routines that are loading at startup?<br>Are you running any 3rd party add-on programs with Autocad?<br>]]>
   <pubDate>Tue, 09 Nov 2010 02:22:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11753&amp;title=system-variable-settings#11753</guid>
   <title><![CDATA[System Variable Settings : Hi Every one,I&amp;#039;m using autoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11726&amp;title=system-variable-settings#11726</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=146110">Muqq</a><br /><strong>Subject:</strong> 4722<br /><strong>Posted:</strong> 07.Nov.2010 at 08:44<br /><br />Hi Every one,<br>I'm using autoCAD 2010 since few days in my cad when opening new file or restart of autocad system variable values are becoming '0'&nbsp; egg. fill mode, mbutton pan , zoom factors this types of&nbsp; command going to 0 i try to reinstall autcad then also problem not solve and when i reset the system variable values untill i close restart of autocad or open nay other cad file its ok after i open any cad file or restart of autcad its same problem <br><br>please any one can help me to solve this problem this irritating me <br><br>thanks<br>]]>
   <pubDate>Sun, 07 Nov 2010 08:44:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4722&amp;PID=11726&amp;title=system-variable-settings#11726</guid>
