  <title>CAD Forum discussion (EN) : Massive UI problems</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Massive UI problems]]></description>
  <pubDate>Tue, 20 Oct 2026 17:28:36 +0000</pubDate>
  <lastBuildDate>Tue, 23 Nov 2010 21:44:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4823</WebWizForums:feedURL>
   <title><![CDATA[Massive UI problems :  The variable editor is quite...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11939&amp;title=massive-ui-problems#11939</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 4823<br /><strong>Posted:</strong> 23.Nov.2010 at 21:44<br /><br />The variable editor is quite usefull but not undocumented/hidden - it is documented in the Help and available in AutoCAD menu/ribbon.<DIV>&nbsp;</DIV><DIV>See <a href="http://www.cadforum.cz/cadforum_en/tips.asp?t=un&#100;ocumented" target="_blank">http://www.cadforum.cz/cadforum_en/tips.asp?t=undocumented</A>&nbsp;for a number of undocumented or underdocumented command and options in AutoCAD.</DIV>]]>
   <pubDate>Tue, 23 Nov 2010 21:44:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11939&amp;title=massive-ui-problems#11939</guid>
   <title><![CDATA[Massive UI problems : THANK YOU SO MUCH!!!!! any other...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11936&amp;title=massive-ui-problems#11936</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=150147">fiors</a><br /><strong>Subject:</strong> 4823<br /><strong>Posted:</strong> 23.Nov.2010 at 20:09<br /><br /><P>THANK YOU SO MUCH!!!!!</P><DIV>any other helpful hidden commands you recommend?</DIV><DIV>&nbsp;</DIV><DIV>Thanks again!</DIV><DIV>Sophia</DIV>]]>
   <pubDate>Tue, 23 Nov 2010 20:09:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11936&amp;title=massive-ui-problems#11936</guid>
   <title><![CDATA[Massive UI problems : I think this is one of the system...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11928&amp;title=massive-ui-problems#11928</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=150189">edwinprakoso</a><br /><strong>Subject:</strong> 4823<br /><strong>Posted:</strong> 23.Nov.2010 at 10:14<br /><br />I think this is one of the system variable problem.<div>Try to type PICKFIRST then enter. If you see the value currently 0, change it to 1.&nbsp;</div><div>I suggest you to backup all system variables and restore it later when you have problem.&nbsp;</div><div><br></div><div><a href="http://cad-notes.com/2010/09/backup-and-restore-autocad-system-variables/" target="_blank" rel="nofollow">http://cad-notes.com/2010/09/backup-and-restore-autocad-system-variables/</a><br></div><div><br></div><div>This is a common problem, I don't know how, but mostly caused by some poor written routines.</div><div><br></div>]]>
   <pubDate>Tue, 23 Nov 2010 10:14:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11928&amp;title=massive-ui-problems#11928</guid>
   <title><![CDATA[Massive UI problems : Hi,   Lesson learned--never...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11926&amp;title=massive-ui-problems#11926</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=150147">fiors</a><br /><strong>Subject:</strong> 4823<br /><strong>Posted:</strong> 23.Nov.2010 at 05:20<br /><br />Hi, <DIV>&nbsp;</DIV><DIV>Lesson learned--never let people mess with your UI.</DIV><DIV>&nbsp;</DIV><DIV>I keep trying to load a UI that I've had for years but it doesnt seem to mend any of my problems--- one big pain in the butt being:</DIV><DIV>&nbsp;</DIV><DIV>When i try to erase</DIV><DIV>cross selection window&gt;e&gt;space</DIV><DIV>it wont let me</DIV><DIV>i can only erase whith e&gt;space&gt;cross selection window&gt;space</DIV><DIV>&nbsp;</DIV><DIV>a selection box pops up every time i hover over lines that are in my aperture box asking which i want to select</DIV><DIV>&nbsp;</DIV><DIV>cross selection windows are acting strange--- essentially selections are off. I've reset the UI, reset the profiles, tried (but failed) to import a profile i set up on another computer... nada</DIV><DIV>&nbsp;</DIV><DIV>i'm all about speed and keyboard commands when i draft--so this is KILLING me.</DIV><DIV>&nbsp;</DIV><DIV>and ideas would be AMAZING!</DIV><DIV>Thank you!!!</DIV><span style="font-size:10px"><br /><br />Edited by fiors - 23.Nov.2010 at 05:21</span>]]>
   <pubDate>Tue, 23 Nov 2010 05:20:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4823&amp;PID=11926&amp;title=massive-ui-problems#11926</guid>
