  <title>CAD Forum discussion (EN) : Redefining a Block</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Redefining a Block]]></description>
  <pubDate>Sun, 06 Sep 2026 13:30:07 +0000</pubDate>
  <lastBuildDate>Fri, 10 Dec 2010 17:08:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4939</WebWizForums:feedURL>
   <title><![CDATA[Redefining a Block : Give the ATTSYNC command a try. ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4939&amp;PID=12177&amp;title=redefining-a-block#12177</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=16131">HAWDesigner</a><br /><strong>Subject:</strong> 4939<br /><strong>Posted:</strong> 10.Dec.2010 at 17:08<br /><br />Give the ATTSYNC command a try.]]>
   <pubDate>Fri, 10 Dec 2010 17:08:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4939&amp;PID=12177&amp;title=redefining-a-block#12177</guid>
   <title><![CDATA[Redefining a Block : I am using autocad map 2010. What...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4939&amp;PID=12162&amp;title=redefining-a-block#12162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2987">ISElation</a><br /><strong>Subject:</strong> 4939<br /><strong>Posted:</strong> 09.Dec.2010 at 16:13<br /><br />I am using autocad map 2010. What I have is a block that has many attributes in it. I go into my block editor and change the color to a few of the attributes and close out. In previous versions of cad i thought it gave you a message saying "there are x many number of blocks out there that have been affected, would you like to update them?" I do not see that any more. Is there a way to update those attributes other than using the battman command. I can't use that command because i use a 3rd party database software attached to autocad that is using this block and there for skews the block after it is synced with the battman command. ]]>
   <pubDate>Thu, 09 Dec 2010 16:13:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4939&amp;PID=12162&amp;title=redefining-a-block#12162</guid>
