  <title>CAD Forum discussion (EN) : DVIEW problems</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : DVIEW problems]]></description>
  <pubDate>Wed, 21 Oct 2026 18:20:26 +0000</pubDate>
  <lastBuildDate>Sun, 02 Jan 2011 07:51:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5001</WebWizForums:feedURL>
   <title><![CDATA[DVIEW problems : My problem solved  ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12436&amp;title=dview-problems#12436</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=158725">jarvisrestorati</a><br /><strong>Subject:</strong> 5001<br /><strong>Posted:</strong> 02.Jan.2011 at 07:51<br /><br />My problem solved]]>
   <pubDate>Sun, 02 Jan 2011 07:51:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12436&amp;title=dview-problems#12436</guid>
   <title><![CDATA[DVIEW problems : I have it as default that &amp;#034;Savelayer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12398&amp;title=dview-problems#12398</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=156946">mdigrigoli</a><br /><strong>Subject:</strong> 5001<br /><strong>Posted:</strong> 22.Dec.2010 at 15:49<br /><br /><P>I have it as default that "Save&nbsp;layer snapshot with view" is checked, but it seems to be a glitch sometimes when changing views. We don't really like using the UCS procedure to rotate views since there's the high percentage of cases that people forget to put the UCS back to World. There are many people in the office working on the same project at the same time and if even one person forgets to set it back to world it messes up with all the xrefs... I don't know what else to do....!</P>]]>
   <pubDate>Wed, 22 Dec 2010 15:49:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12398&amp;title=dview-problems#12398</guid>
   <title><![CDATA[DVIEW problems : When you create a view there is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12393&amp;title=dview-problems#12393</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=46912">Lexxx</a><br /><strong>Subject:</strong> 5001<br /><strong>Posted:</strong> 22.Dec.2010 at 11:58<br /><br />When you create a view there is an option to "Save&nbsp;layer snapshot with view". <DIV>This means that is will restore the layers to what they were set to when the view was created. </DIV><span style="font-size:10px"><br /><br />Edited by Lexxx - 22.Dec.2010 at 11:59</span>]]>
   <pubDate>Wed, 22 Dec 2010 11:58:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12393&amp;title=dview-problems#12393</guid>
   <title><![CDATA[DVIEW problems : Sounds like youmay wantto usenamed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12388&amp;title=dview-problems#12388</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 5001<br /><strong>Posted:</strong> 22.Dec.2010 at 00:16<br /><br />Sounds like you&nbsp;may want&nbsp;to use&nbsp;named UCS's rather than named views, so that layer settings aren't changed. But, restoring a UCS doesn't restore&nbsp;the&nbsp;original view (zoom and pan).]]>
   <pubDate>Wed, 22 Dec 2010 00:16:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12388&amp;title=dview-problems#12388</guid>
   <title><![CDATA[DVIEW problems : Hi, I would like some advise,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12376&amp;title=dview-problems#12376</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=156946">mdigrigoli</a><br /><strong>Subject:</strong> 5001<br /><strong>Posted:</strong> 20.Dec.2010 at 22:02<br /><br /><P>Hi, I would like some advise, whenever here at the office we create views for our plans we do so using the DVIEW command and then the TWIST option&nbsp;and VIEW to name them. But when we go and do the switch between views we get into the problem that many of the layers that belong to the XREFS are frozen automatically and francly it's a pain to be thawing them all each and everytime we switch views...does anyone know why this happens and how to fix it. Is there a more efficient way of rotating views? We do it this way because many people use the drawings and that way we can name the views the same throughout the project... Please HELP!</P>]]>
   <pubDate>Mon, 20 Dec 2010 22:02:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5001&amp;PID=12376&amp;title=dview-problems#12376</guid>
