  <title>CAD Forum discussion (EN) : HI!SOLUTION NEEDED IN AUTOCAD2010</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : HI!SOLUTION NEEDED IN AUTOCAD2010]]></description>
  <pubDate>Sat, 05 Sep 2026 08:38:16 +0000</pubDate>
  <lastBuildDate>Thu, 06 Jan 2011 15:05:05 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5071</WebWizForums:feedURL>
   <title><![CDATA[HI!SOLUTION NEEDED IN AUTOCAD2010 : You can create walls with straight...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5071&amp;PID=12506&amp;title=hisolution-needed-in-autocad2010#12506</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=16131">HAWDesigner</a><br /><strong>Subject:</strong> 5071<br /><strong>Posted:</strong> 06.Jan.2011 at 15:05<br /><br /><font color="#000000">You can create walls with straight and curved segments of constant height and width.<br><br>With the &#091;CMD&#093;POLYSOLID&#091;/CMD&#093; command, you can convert an existing line, 2D polyline, arc, or circle <b>(NOT A SPLINE)</b> to a solid with a rectangular profile. A polysolid can have curved segments, but the profile is always rectangular by default.<br><br>I hope this helps! Good Luck!!</font><span style="font-size:10px"><br /><br />Edited by HAWDesigner - 06.Jan.2011 at 15:06</span>]]>
   <pubDate>Thu, 06 Jan 2011 15:05:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5071&amp;PID=12506&amp;title=hisolution-needed-in-autocad2010#12506</guid>
   <title><![CDATA[HI!SOLUTION NEEDED IN AUTOCAD2010 : 2HI,ALL! I hav drawn an object...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5071&amp;PID=12505&amp;title=hisolution-needed-in-autocad2010#12505</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=159588">ARCH.JR</a><br /><strong>Subject:</strong> 5071<br /><strong>Posted:</strong> 06.Jan.2011 at 14:33<br /><br /><font size="2">2</font>HI,ALL!<br />I hav drawn an object usin line and splines.<br /> now,im tryin to polysolid this shape but when im goin to select the spline line...i get "object cannot be selected".<br />though the parts that r drawn with the line command accept the polysolid command.<br />any suggestions?<br />whats wrong? is the way i draw the shape?<br />thanks! <img src="https://www.cadforum.cz/forum_en/smileys/smiley1.gif" border="0" align="middle" /> ]]>
   <pubDate>Thu, 06 Jan 2011 14:33:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5071&amp;PID=12505&amp;title=hisolution-needed-in-autocad2010#12505</guid>
