  <title>CAD Forum discussion (EN) : DefPoints</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : DefPoints]]></description>
  <pubDate>Thu, 29 Oct 2026 15:52:55 +0000</pubDate>
  <lastBuildDate>Mon, 24 Jan 2011 13:18:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5172</WebWizForums:feedURL>
   <title><![CDATA[DefPoints : DefPoint Layer was not turned...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12814&amp;title=defpoints#12814</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=163130">Uhrenlothar</a><br /><strong>Subject:</strong> 5172<br /><strong>Posted:</strong> 24.Jan.2011 at 13:18<br /><br />DefPoint Layer was not turned off but layer 0. see previous message<br />Thamks anyhow]]>
   <pubDate>Mon, 24 Jan 2011 13:18:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12814&amp;title=defpoints#12814</guid>
   <title><![CDATA[DefPoints : Thank you 0 was turned off ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12813&amp;title=defpoints#12813</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=163130">Uhrenlothar</a><br /><strong>Subject:</strong> 5172<br /><strong>Posted:</strong> 24.Jan.2011 at 13:17<br /><br />Thank you 0 was turned off]]>
   <pubDate>Mon, 24 Jan 2011 13:17:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12813&amp;title=defpoints#12813</guid>
   <title><![CDATA[DefPoints : Check for the lock on the layer......]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12810&amp;title=defpoints#12810</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=126607">Rikky</a><br /><strong>Subject:</strong> 5172<br /><strong>Posted:</strong> 24.Jan.2011 at 08:49<br /><br />Check for the lock on the layer...]]>
   <pubDate>Mon, 24 Jan 2011 08:49:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12810&amp;title=defpoints#12810</guid>
   <title><![CDATA[DefPoints : If Layer 0 is turned Off or Frozen,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12806&amp;title=defpoints#12806</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 5172<br /><strong>Posted:</strong> 23.Jan.2011 at 16:30<br /><br />If Layer 0 is turned Off or Frozen, you will not be able to select any objects on the Defpoints layer. So make sure Layer 0 is On and Thawed and you should be able to select and delete the dimension.]]>
   <pubDate>Sun, 23 Jan 2011 16:30:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12806&amp;title=defpoints#12806</guid>
   <title><![CDATA[DefPoints : AutoCAD LT 2002, Windows PX SP3  Involuntarily...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12805&amp;title=defpoints#12805</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=163130">Uhrenlothar</a><br /><strong>Subject:</strong> 5172<br /><strong>Posted:</strong> 23.Jan.2011 at 14:48<br /><br />AutoCAD LT 2002, Windows PX SP3<br /><br />Involuntarily I places an object (a dimension) on the layer "DefPoints". <br />Now I can neither erase nor do any other command with this object. I have erased all my dimensioning and cleared my layers the misplaces dimension will not vanish.<br /><br />Help needed<br />Uhrenlothar<br />]]>
   <pubDate>Sun, 23 Jan 2011 14:48:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5172&amp;PID=12805&amp;title=defpoints#12805</guid>
