  <title>CAD Forum discussion (EN) : 3D surface edges</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 3D surface edges]]></description>
  <pubDate>Sun, 25 Oct 2026 13:54:09 +0000</pubDate>
  <lastBuildDate>Mon, 31 Jan 2011 15:42:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5213</WebWizForums:feedURL>
   <title><![CDATA[3D surface edges : Thank you. That was very helpful....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12980&amp;title=3d-surface-edges#12980</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=164625">justasec</a><br /><strong>Subject:</strong> 5213<br /><strong>Posted:</strong> 31.Jan.2011 at 15:42<br /><br />Thank you. That was very helpful.]]>
   <pubDate>Mon, 31 Jan 2011 15:42:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12980&amp;title=3d-surface-edges#12980</guid>
   <title><![CDATA[3D surface edges : Display of edges may be controlled...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12944&amp;title=3d-surface-edges#12944</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 5213<br /><strong>Posted:</strong> 28.Jan.2011 at 23:16<br /><br />Display of edges may be controlled by the DISPSILH setting.&nbsp; (may have been covered by HAWSdesigner suggestions...)<span style="font-size:10px"><br /><br />Edited by CarlB - 28.Jan.2011 at 23:17</span>]]>
   <pubDate>Fri, 28 Jan 2011 23:16:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12944&amp;title=3d-surface-edges#12944</guid>
   <title><![CDATA[3D surface edges :  I&amp;#039;m assuming you&amp;#039;re...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12943&amp;title=3d-surface-edges#12943</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=16131">HAWDesigner</a><br /><strong>Subject:</strong> 5213<br /><strong>Posted:</strong> 28.Jan.2011 at 23:00<br /><br />I'm assuming you're using your Visual Style Manager to make the changes. Have you tried adjusting some of the settings?<br><br>I think the Edge Settings may be what you want to adjust. When I set mine, I changed the color from "White" to "by Entity". Just doing this made a world of difference in how the product showed up in print.<br><br>You can also change the Edge Mode (turn the Edges OFF) or even adjust the Edge modifiers (such as Overhang and Jitter).<br><br>Does this help?<br><span style="font-size:10px"><br /><br />Edited by HAWDesigner - 28.Jan.2011 at 23:04</span>]]>
   <pubDate>Fri, 28 Jan 2011 23:00:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12943&amp;title=3d-surface-edges#12943</guid>
   <title><![CDATA[3D surface edges : Hi all. Running AutoCAD 2009.  I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12940&amp;title=3d-surface-edges#12940</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=164625">justasec</a><br /><strong>Subject:</strong> 5213<br /><strong>Posted:</strong> 28.Jan.2011 at 22:49<br /><br />Hi all. Running AutoCAD 2009.<br /><br />I am looking for a way to turn off surface edges to make a "3d hidden" appear nicer without effecting how the "Realistic" view appears.<br /><br />It is an existing file containing thousands of surfaces, so I am hoping there is a fast, possibly group, selection tool for this.<br /><br />I have been unable to find a solution in the help menu.<br /><br />Thanks]]>
   <pubDate>Fri, 28 Jan 2011 22:49:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5213&amp;PID=12940&amp;title=3d-surface-edges#12940</guid>
