  <title>CAD Forum discussion (EN) : Isolate layer issue</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Isolate layer issue]]></description>
  <pubDate>Sat, 13 Jun 2026 06:39:40 +0000</pubDate>
  <lastBuildDate>Tue, 01 Feb 2011 03:16:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5235</WebWizForums:feedURL>
   <title><![CDATA[Isolate layer issue : OMG... THANK YOU!!!! ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5235&amp;PID=12996&amp;title=isolate-layer-issue#12996</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=116931">AnnieC</a><br /><strong>Subject:</strong> 5235<br /><strong>Posted:</strong> 01.Feb.2011 at 03:16<br /><br />OMG...&nbsp; THANK YOU!!!!&nbsp;]]>
   <pubDate>Tue, 01 Feb 2011 03:16:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5235&amp;PID=12996&amp;title=isolate-layer-issue#12996</guid>
   <title><![CDATA[Isolate layer issue : Command: layiso Current setting:...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5235&amp;PID=12994&amp;title=isolate-layer-issue#12994</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 5235<br /><strong>Posted:</strong> 01.Feb.2011 at 03:03<br /><br /><DIV>Command: layiso</DIV><P>Current setting: Hide layers, Viewports=Off</P><P>Select objects on the layer(s) to be isolated or &#091;Settings&#093;: <strong>S</strong></P><P>Enter setting for layers not isolated &#091;Off/Lock and fade&#093; &lt;Off&gt;: <strong>Off</strong></P><P>In paper space viewport use &#091;Vpfreeze/Off&#093; &lt;Off&gt;: <strong>V</strong></P><P>Select objects on the layer(s) to be isolated or &#091;Settings&#093;: <strong>&#091;return&#093;</strong></P>]]>
   <pubDate>Tue, 01 Feb 2011 03:03:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5235&amp;PID=12994&amp;title=isolate-layer-issue#12994</guid>
   <title><![CDATA[Isolate layer issue : I am using the isolate layer key...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5235&amp;PID=12993&amp;title=isolate-layer-issue#12993</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=116931">AnnieC</a><br /><strong>Subject:</strong> 5235<br /><strong>Posted:</strong> 01.Feb.2011 at 02:39<br /><br />I am using the isolate layer key in AutoCAD 2011.&nbsp; It is locking my layers not frezing them.&nbsp; Does anyone know how to change this setting???]]>
   <pubDate>Tue, 01 Feb 2011 02:39:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5235&amp;PID=12993&amp;title=isolate-layer-issue#12993</guid>
