  <title>CAD Forum discussion (EN) : Which version are you running?</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : -CAD Forum- (read-only) : Which version are you running?]]></description>
  <pubDate>Fri, 09 Oct 2026 04:38:53 +0000</pubDate>
  <lastBuildDate>Fri, 14 Oct 2011 12:14:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5259</WebWizForums:feedURL>
   <title><![CDATA[Which version are you running? : Well! I&amp;#039;m gonna dig your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=17406&amp;title=which-version-are-you-running#17406</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=221369">ElliotSutton</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 14.Oct.2011 at 12:14<br /><br />Well!<br><br>&nbsp; I'm gonna dig your sported links. Actually i have several documents and files to be convert.<br><br><br><br><br><br>Thanks,<br>Elliot.<br><br><br>]]>
   <pubDate>Fri, 14 Oct 2011 12:14:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=17406&amp;title=which-version-are-you-running#17406</guid>
   <title><![CDATA[Which version are you running? : I don&amp;#039;t think he even knows...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=17396&amp;title=which-version-are-you-running#17396</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 13.Oct.2011 at 21:27<br /><br />I don't think he even knows what Autocad is. If he did, he probably wouldn't have posted that reply.<br><br>ElliotSutton, if you want to know what unique features AutoCAD has, take a look here: <a href="http://usa.autodesk.com/autocad/" target="_blank" rel="nofollow">http://usa.autodesk.com/autocad/.</a> Then come back and tell us how your pdf editing software compares.<br>]]>
   <pubDate>Thu, 13 Oct 2011 21:27:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=17396&amp;title=which-version-are-you-running#17396</guid>
   <title><![CDATA[Which version are you running? :  If you don&amp;#039;t use an AutoDesk...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=17389&amp;title=which-version-are-you-running#17389</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 12.Oct.2011 at 13:12<br /><br />If you don't use an AutoDesk product what is the point of posting in the CADforum unless it is to get yourself a free product placement ad?<br><br>Try drawing the plans for the Freedom Tower with your software then you'll realize how AutoCAD or AutoCAD Architecture would be a better choice.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 12.Oct.2011 at 13:14</span>]]>
   <pubDate>Wed, 12 Oct 2011 13:12:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=17389&amp;title=which-version-are-you-running#17389</guid>
   <title><![CDATA[Which version are you running? : im using autoCAD2007 and 2008......]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=16447&amp;title=which-version-are-you-running#16447</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=207430">eron04</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 01.Aug.2011 at 16:01<br /><br />im using autoCAD2007 and 2008...]]>
   <pubDate>Mon, 01 Aug 2011 16:01:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=16447&amp;title=which-version-are-you-running#16447</guid>
   <title><![CDATA[Which version are you running? : Just don&amp;#039;t want to post as...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15839&amp;title=which-version-are-you-running#15839</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 20.Jun.2011 at 13:08<br /><br />Just don't want to post as a new question do you?<br><br>Break the drawing up into manageable pieces and plot from a paper space layout using a standard scale.<br>]]>
   <pubDate>Mon, 20 Jun 2011 13:08:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15839&amp;title=which-version-are-you-running#15839</guid>
   <title><![CDATA[Which version are you running? : I am using acad 2012 problem is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15838&amp;title=which-version-are-you-running#15838</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=43452">VIJAYABIND</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 20.Jun.2011 at 12:53<br /><br /><p>I am using acad 2012 problem is site plans (very long distance dwg about 60km total site plan area) any technic please advise me&nbsp;</p><p>thank you</p>]]>
   <pubDate>Mon, 20 Jun 2011 12:53:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15838&amp;title=which-version-are-you-running#15838</guid>
   <title><![CDATA[Which version are you running? :    VIJAYABIND wrote:  site...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15836&amp;title=which-version-are-you-running#15836</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 20.Jun.2011 at 12:31<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by VIJAYABIND" alt="Originally posted by VIJAYABIND" style="vertical-align: text-bottom;" /> <strong>VIJAYABIND wrote:</strong><br /><br /><p>site plan (very long distance abiut 60km) how to take pintout with readable</p><p>please explain&nbsp;</p></td></tr></table><br><br>Odd place to post a question isn't it?&nbsp; This thread is a reminder to forum users to mention what AutoDesk product they are using and version number.&nbsp; It has nothing to do with printing a drawing.<br><br>You should repost your question as a new thread.&nbsp; A little more detail would help too.<br>]]>
   <pubDate>Mon, 20 Jun 2011 12:31:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15836&amp;title=which-version-are-you-running#15836</guid>
   <title><![CDATA[Which version are you running? :   site plan (very long distance...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15835&amp;title=which-version-are-you-running#15835</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=43452">VIJAYABIND</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 20.Jun.2011 at 12:28<br /><br /><p>site plan (very long distance abiut 60km) how to take pintout with readable</p><p>please explain&nbsp;</p>]]>
   <pubDate>Mon, 20 Jun 2011 12:28:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15835&amp;title=which-version-are-you-running#15835</guid>
   <title><![CDATA[Which version are you running? : i am running...autocad 2006 and...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15794&amp;title=which-version-are-you-running#15794</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=199150">kami_rock55</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 16.Jun.2011 at 21:35<br /><br />i am running...autocad 2006 and 2010.]]>
   <pubDate>Thu, 16 Jun 2011 21:35:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15794&amp;title=which-version-are-you-running#15794</guid>
   <title><![CDATA[Which version are you running? : The question is so obvious John....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15443&amp;title=which-version-are-you-running#15443</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 5259<br /><strong>Posted:</strong> 21.May.2011 at 20:29<br /><br />The question is so obvious John. I can't believe you don't see it. Skygirl is an interior designer, currently using Revit, but she's also interested in fashion. So she wants to know if she can use lisp routines in Revit 2010 to design clothing for the fashion industry. It's all there in the post. Although I may have embellished just a little. <img src="https://www.cadforum.cz/forum_en/smileys/smiley9.gif" border="0" align="absmiddle" alt="Embarrassed" /><br><br><br><br><br>]]>
   <pubDate>Sat, 21 May 2011 20:29:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5259&amp;PID=15443&amp;title=which-version-are-you-running#15443</guid>
