  <title>CAD Forum discussion (EN) : Publish</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Publish]]></description>
  <pubDate>Fri, 17 Jul 2026 04:33:24 +0000</pubDate>
  <lastBuildDate>Thu, 12 Jun 2008 07:26:13 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=530</WebWizForums:feedURL>
   <title><![CDATA[Publish : hi ya,   in addition to this....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=530&amp;PID=2135&amp;title=publish#2135</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=12482">sim_rx3</a><br /><strong>Subject:</strong> 530<br /><strong>Posted:</strong> 12.Jun.2008 at 07:26<br /><br />hi ya, <DIV>&nbsp;</DIV><DIV>in addition to this. i know how publish works etc.</DIV><DIV>&nbsp;</DIV><DIV>im trying to do batch pdfing through publish as its a customer requirement to produce pdf's.</DIV><DIV>&nbsp;</DIV><DIV>i used to do it in the previous company i was with but when you used publish with a pdfing tool, publish would open print and close the drawings infront of you instead of doing it in the background.</DIV><DIV>&nbsp;</DIV><DIV>what is the command to change this feature as the company im with atm its trying to do it in the background. it creates the first pdf then says its finished when its not.</DIV><DIV>&nbsp;</DIV><DIV>thanks in advance</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>edit: sorry i found it.</DIV><DIV>&nbsp;</DIV><DIV>from pull down menu</DIV><DIV>&nbsp;</DIV><DIV>tools&gt;options</DIV><DIV>&nbsp;</DIV><DIV>select plot and publish file</DIV><DIV>&nbsp;</DIV><DIV>mid way on left side is the selection box for publishing in foreground or background. de-ticking them makes autocad publish and print in the foreground.</DIV><span style="font-size:10px"><br /><br />Edited by sim_rx3 - 12.Jun.2008 at 07:35</span>]]>
   <pubDate>Thu, 12 Jun 2008 07:26:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=530&amp;PID=2135&amp;title=publish#2135</guid>
   <title><![CDATA[Publish :  See this: http://usa.autode...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=530&amp;PID=1357&amp;title=publish#1357</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 530<br /><strong>Posted:</strong> 06.Mar.2008 at 10:13<br /><br /><DIV></DIV>&nbsp;<DIV>&nbsp;See this:</DIV><DIV>http://usa.autodesk.com/adsk/servlet/item?siteID=123112&amp;id=3574968&amp;linkID=9240615</DIV>]]>
   <pubDate>Thu, 06 Mar 2008 10:13:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=530&amp;PID=1357&amp;title=publish#1357</guid>
   <title><![CDATA[Publish : I am trying to batch plot (publish)...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=530&amp;PID=1331&amp;title=publish#1331</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=5369">Rainman</a><br /><strong>Subject:</strong> 530<br /><strong>Posted:</strong> 28.Feb.2008 at 15:20<br /><br />I am trying to batch plot (publish) a set of drawings. I get to the point where I create a dwf file but I am not sure how to actually plot after this point. Am I correct in creating a dwf file? I think I am on the right track. How do I import a page set-up template?]]>
   <pubDate>Thu, 28 Feb 2008 15:20:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=530&amp;PID=1331&amp;title=publish#1331</guid>
