  <title>CAD Forum discussion (EN) : Structural Members Catalog</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : Structural Members Catalog]]></description>
  <pubDate>Mon, 28 Sep 2026 16:51:21 +0000</pubDate>
  <lastBuildDate>Wed, 16 Feb 2011 20:17:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5319</WebWizForums:feedURL>
   <title><![CDATA[Structural Members Catalog : Actually I tried placing a WF...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5319&amp;PID=13381&amp;title=structural-members-catalog#13381</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=160989">RENEEMC</a><br /><strong>Subject:</strong> 5319<br /><strong>Posted:</strong> 16.Feb.2011 at 20:17<br /><br />Actually I tried placing a WF beam from the Design Center and discovered that when I select it, I get a drop down menu to choose the size I need. That will work for now, but a "full" Library would be nice. Steel joists are not one of the options so I'm going to wing-it! I don't normally do structural; I'm usually modeling corridors and the usual Civil stuff.]]>
   <pubDate>Wed, 16 Feb 2011 20:17:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5319&amp;PID=13381&amp;title=structural-members-catalog#13381</guid>
   <title><![CDATA[Structural Members Catalog : It almost sounds like you are...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5319&amp;PID=13378&amp;title=structural-members-catalog#13378</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5319<br /><strong>Posted:</strong> 16.Feb.2011 at 19:22<br /><br />It almost sounds like you are looking at a "sample" instead of the "full" library.<DIV>What happens if you right-click on one of the tabs way down at the bottom where they all tend to bunch up and overlap each other?&nbsp; Do you get a flyout menu?</DIV>]]>
   <pubDate>Wed, 16 Feb 2011 19:22:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5319&amp;PID=13378&amp;title=structural-members-catalog#13378</guid>
