  <title>CAD Forum discussion (EN) : Revision block attribute extract</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Revision block attribute extract]]></description>
  <pubDate>Thu, 05 Nov 2026 15:01:02 +0000</pubDate>
  <lastBuildDate>Fri, 25 Feb 2011 01:33:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5370</WebWizForums:feedURL>
   <title><![CDATA[Revision block attribute extract :   Hi guys, I have one challenge...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5370&amp;PID=13549&amp;title=revision-block-attribute-extract#13549</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=164791">kameron1967</a><br /><strong>Subject:</strong> 5370<br /><strong>Posted:</strong> 25.Feb.2011 at 01:33<br /><br /><DIV ="lia-message- lia-comp&#111;nent-"><DIV =lia-message--c&#111;ntent><P>Hi guys,</P><DIV>I have one challenge that I need help with.&nbsp; It relates to getting the latest revision block's rev number or letter and revision date.&nbsp; The revision blocks will be the same name, but the&nbsp;revision&nbsp;letter or number&nbsp;(A,B,C,D,0,1,2,3,4,5) would be in the block.&nbsp; So assuming that there's 3 blocks (all named RevblockA) and attribute tag "#" and revision date tag "DATE", how can I obtain the highest rev and date, if it exists and update the dwgprops field for KEYWORDS (for Rev #)&nbsp;and COMMENTS (For Rev Date), respectively?</DIV><P>&nbsp;</P><P>Thanks in advance.</P></DIV></DIV>]]>
   <pubDate>Fri, 25 Feb 2011 01:33:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5370&amp;PID=13549&amp;title=revision-block-attribute-extract#13549</guid>
