  <title>CAD Forum discussion (EN) : levels</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : levels]]></description>
  <pubDate>Wed, 28 Oct 2026 06:58:22 +0000</pubDate>
  <lastBuildDate>Mon, 28 Feb 2011 12:30:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5383</WebWizForums:feedURL>
   <title><![CDATA[levels : Sounds like the lisp program POINT...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13586&amp;title=levels#13586</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5383<br /><strong>Posted:</strong> 28.Feb.2011 at 12:30<br /><br />Sounds like the lisp program POINT MANAGER by Lee Mac Programming might do the trick.&nbsp; Find it here:<DIV>&nbsp;</DIV><DIV><a href="http://lee-mac.com/ptmanager.html" target="_blank" rel="nofollow">http://lee-mac.com/ptmanager.html</A></DIV>]]>
   <pubDate>Mon, 28 Feb 2011 12:30:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13586&amp;title=levels#13586</guid>
   <title><![CDATA[levels : sorry yes i ment spot elevations...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13585&amp;title=levels#13585</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=171799">russ.sparrow</a><br /><strong>Subject:</strong> 5383<br /><strong>Posted:</strong> 28.Feb.2011 at 12:17<br /><br /><FONT face="Arial, Helvetica, sans-serif" color=#000000 size=3>sorry yes i ment spot elevations (eg 94.000)ive never tried to do this before and i have learnt to use autocad myself so my level of </FONT><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><FONT face="Arial, Helvetica, sans-serif" color=#000000 size=3>Knowledge is fairly low. any help anyone can give (hopefully in laymans terms) would be a great help</FONT></P>]]>
   <pubDate>Mon, 28 Feb 2011 12:17:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13585&amp;title=levels#13585</guid>
   <title><![CDATA[levels : When you say &amp;#034;survey levels&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13583&amp;title=levels#13583</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5383<br /><strong>Posted:</strong> 28.Feb.2011 at 12:04<br /><br />When you say "survey levels" are you talking about spot elevations?<DIV>&nbsp;</DIV><DIV>I think you can bring the spot elevations into AutoCAD 2011 using a lisp routine.&nbsp; I'm not sure about how it would be done in AutoCAD LT because lisp is not supported in that program.&nbsp; Perhaps with a script file?</DIV>]]>
   <pubDate>Mon, 28 Feb 2011 12:04:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13583&amp;title=levels#13583</guid>
   <title><![CDATA[levels : hi all can anyone help me, i&amp;#039;m...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13582&amp;title=levels#13582</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=171799">russ.sparrow</a><br /><strong>Subject:</strong> 5383<br /><strong>Posted:</strong> 28.Feb.2011 at 11:23<br /><br />hi all<DIV>can anyone help me, i'm trying to find if you can input surveying levels into autocad and if so how. i'm running 2006LT at work and 2011 at home.</DIV><DIV>Any help would great</DIV><DIV>many thanks in advance</DIV>]]>
   <pubDate>Mon, 28 Feb 2011 11:23:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5383&amp;PID=13582&amp;title=levels#13582</guid>
