  <title>CAD Forum discussion (EN) : Varying lineweights on similar text</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Varying lineweights on similar text]]></description>
  <pubDate>Mon, 26 Oct 2026 09:17:08 +0000</pubDate>
  <lastBuildDate>Mon, 28 Feb 2011 19:28:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5386</WebWizForums:feedURL>
   <title><![CDATA[Varying lineweights on similar text : Glad to hear that you got it sorted...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13603&amp;title=varying-lineweights-on-similar-text#13603</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5386<br /><strong>Posted:</strong> 28.Feb.2011 at 19:28<br /><br />Glad to hear that you got it sorted out.&nbsp; Sometimes it's the smallest things that trip us up.<DIV>&nbsp;</DIV><DIV>You're welcomed.</DIV>]]>
   <pubDate>Mon, 28 Feb 2011 19:28:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13603&amp;title=varying-lineweights-on-similar-text#13603</guid>
   <title><![CDATA[Varying lineweights on similar text : I almost just posted &amp;#034;NO&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13601&amp;title=varying-lineweights-on-similar-text#13601</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=159023">JSketch</a><br /><strong>Subject:</strong> 5386<br /><strong>Posted:</strong> 28.Feb.2011 at 19:01<br /><br />I almost just posted "NO" without trying it out.&nbsp; I originally compared the properties box of both texts and never noticed a difference.&nbsp; My problem was that both "z Coordinates" stated "0'" because the one that was elevated was higher by less than 1/64th so it just rounded to 0'.&nbsp; I just hit "0" in the field and hit tab and "BOOM!", all the same appearance.<br><br>No idea how I managed to "Chris Angel" the text but I'll keep my eye out for it from now on.<br><br>Thanks<br>]]>
   <pubDate>Mon, 28 Feb 2011 19:01:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13601&amp;title=varying-lineweights-on-similar-text#13601</guid>
   <title><![CDATA[Varying lineweights on similar text : Could the emboldened text have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13599&amp;title=varying-lineweights-on-similar-text#13599</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5386<br /><strong>Posted:</strong> 28.Feb.2011 at 17:22<br /><br />Could the emboldened text have a Z elevation greater than "0"?]]>
   <pubDate>Mon, 28 Feb 2011 17:22:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13599&amp;title=varying-lineweights-on-similar-text#13599</guid>
   <title><![CDATA[Varying lineweights on similar text : I have an issue I&amp;#039;ve been...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13598&amp;title=varying-lineweights-on-similar-text#13598</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=159023">JSketch</a><br /><strong>Subject:</strong> 5386<br /><strong>Posted:</strong> 28.Feb.2011 at 17:21<br /><br />I have an issue I've been dealing with for a while (years of AutoCAD versions).&nbsp; I'm sure someone out there has a fix:<br><br>This happens probably every 4th or 5th drawing I create.&nbsp; I can create multiple texts on a sheet/model (either TEXT or MTEXT) using the same layer, lineweight, text size, annotative or not, etc; all exactly the same.&nbsp; Somehow, every now and again one of those texts will display as emboldened on the screen, and more importantly, plots that way as well.&nbsp; My only fix so far is to kill the text and create or copy/paste a new one.<br><br>Any ideas?&nbsp; I'm open to all suggestions.<br><br>Thank you for your time.<br>]]>
   <pubDate>Mon, 28 Feb 2011 17:21:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5386&amp;PID=13598&amp;title=varying-lineweights-on-similar-text#13598</guid>
