  <title>CAD Forum discussion (EN) : ltscale keeps changing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : ltscale keeps changing]]></description>
  <pubDate>Fri, 04 Sep 2026 12:45:12 +0000</pubDate>
  <lastBuildDate>Sat, 19 Mar 2011 00:41:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5501</WebWizForums:feedURL>
   <title><![CDATA[ltscale keeps changing : Thanks. I will try it on monday...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14164&amp;title=ltscale-keeps-changing#14164</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23579">luke59</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 19.Mar.2011 at 00:41<br /><br />Thanks. I will try it on monday when I go back to the office. Much appreciated.&nbsp;]]>
   <pubDate>Sat, 19 Mar 2011 00:41:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14164&amp;title=ltscale-keeps-changing#14164</guid>
   <title><![CDATA[ltscale keeps changing : I think I found an answer to your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14161&amp;title=ltscale-keeps-changing#14161</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 22:56<br /><br />I think I found an answer to your problem or at the very least a fix.&nbsp; You can download from this website a lisp program called SYSVARLOCK that will basically lock your system variables once they are set so they cannot be reset.<br><br>Click on the link below.&nbsp; When you get to the page use your Page Down key numerous times to get way, way down the list to the section called CAD Utilities.&nbsp; Look for SysVarLock, click on the floppy disk to the left and download the .rar file and extract the lisp routine.&nbsp; Use the Appload command to load it.&nbsp; Make sure you are in model space and have just reset your LTSCALE to 1 before running the routine.<br><br>Caveat: I haven't used the routine so I can't tell you for sure whether it works as promised or not.&nbsp; You'll have to test it for yourself.&nbsp; Good luck.<br><br>http://www.cadstudio.cz/en/download.asp<br><br>]]>
   <pubDate>Fri, 18 Mar 2011 22:56:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14161&amp;title=ltscale-keeps-changing#14161</guid>
   <title><![CDATA[ltscale keeps changing : I&amp;#039;m stalling at the moment....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14160&amp;title=ltscale-keeps-changing#14160</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 22:41<br /><br />I'm stalling at the moment.&nbsp; I thought I came across something early in an Internet search but when you did not reply to my last question I axed the web page and went on to something else.&nbsp; Now I'm having a problem remembering what I used as my search criteria.&nbsp; Give me a few moments maybe it will come to me.<span style="font-size:10px"><br /><br />Edited by John Connor - 18.Mar.2011 at 22:45</span>]]>
   <pubDate>Fri, 18 Mar 2011 22:41:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14160&amp;title=ltscale-keeps-changing#14160</guid>
   <title><![CDATA[ltscale keeps changing : sorry about that. It happens on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14159&amp;title=ltscale-keeps-changing#14159</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23579">luke59</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 22:34<br /><br />sorry about that. It happens on every drawing I do. No there are no custom lisp routines.]]>
   <pubDate>Fri, 18 Mar 2011 22:34:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14159&amp;title=ltscale-keeps-changing#14159</guid>
   <title><![CDATA[ltscale keeps changing :  It is always helpful to us if...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14135&amp;title=ltscale-keeps-changing#14135</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 15:56<br /><br />It is always helpful to us if we know our advice worked or it didn't.<br><br>Does this same odd behavior occur in any other drawing other than this one or is it an isolated event?<br><br>One other question, do you use any custom lisp routines?<br><span style="font-size:10px"><br /><br />Edited by John Connor - 18.Mar.2011 at 16:04</span>]]>
   <pubDate>Fri, 18 Mar 2011 15:56:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14135&amp;title=ltscale-keeps-changing#14135</guid>
   <title><![CDATA[ltscale keeps changing : sorry. i meant thanks for the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14133&amp;title=ltscale-keeps-changing#14133</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23579">luke59</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 15:30<br /><br />sorry. i meant thanks for the help but it still didn't work. I changed it and then I go to paper space and comeback to model in changes it back to .4]]>
   <pubDate>Fri, 18 Mar 2011 15:30:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14133&amp;title=ltscale-keeps-changing#14133</guid>
   <title><![CDATA[ltscale keeps changing :    luke59 wrote:Thanks Thanks...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14131&amp;title=ltscale-keeps-changing#14131</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 15:14<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by luke59" alt="Originally posted by luke59" style="vertical-align: text-bottom;" /> <strong>luke59 wrote:</strong><br /><br />Thanks</td></tr></table><br>Thanks for the suggestion or "Thanks. it worked"?&nbsp; I hope it was the latter.&nbsp; LOL<br>]]>
   <pubDate>Fri, 18 Mar 2011 15:14:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14131&amp;title=ltscale-keeps-changing#14131</guid>
   <title><![CDATA[ltscale keeps changing : Thanks  ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14130&amp;title=ltscale-keeps-changing#14130</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23579">luke59</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 15:13<br /><br />Thanks]]>
   <pubDate>Fri, 18 Mar 2011 15:13:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14130&amp;title=ltscale-keeps-changing#14130</guid>
   <title><![CDATA[ltscale keeps changing : Try doing it this way and see...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14127&amp;title=ltscale-keeps-changing#14127</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 15:07<br /><br /><p id="d0e41718" ="list-intro"><a name="TOC_ENTRY__d0e41718"></a><span style="display: n&#111;ne;"><a name="WS1a9193826455f5ffa23ce210c4a30acaf-728d"></a></span>Try doing it this way and see if it makes any difference.<br></p><p id="d0e41718" ="list-intro">To change linetype scale globally </p><ol ="1"><li><span style="display: n&#111;ne;"><a name="WS1a9193826455f5ff-4855151011e22f62443-5409"></a></span>Click <span ="uis-unspecified">Home tab </span><span ="glyphArrow" name="glyph_span">&gt;</span><span ="uis-unspecified"> Properties panel &gt; </span><span ="glyphArrow" name="glyph_span"></span><span ="uis-unspecified"> Linetype.&nbsp;</span> </li><li><span style="display: n&#111;ne;"><a name="WS1a9193826455f5ff-2ade9d9118a20d4f814ef2"></a></span>In the Linetype Manager, click Show Details to expand the dialog box. </li><li><span style="display: n&#111;ne;"><a name="WS1a9193826455f5ff-2ade9d9118a20d4f814ef3"></a></span>Enter a new value for Global Scale Factor. </li><li><span style="display: n&#111;ne;"><a name="WS1a9193826455f5ff-2ade9d9118a20d4f814ef4"></a></span>Click OK.</li></ol>]]>
   <pubDate>Fri, 18 Mar 2011 15:07:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14127&amp;title=ltscale-keeps-changing#14127</guid>
   <title><![CDATA[ltscale keeps changing : I have AutoCAD 2010. i have a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14126&amp;title=ltscale-keeps-changing#14126</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23579">luke59</a><br /><strong>Subject:</strong> 5501<br /><strong>Posted:</strong> 18.Mar.2011 at 15:03<br /><br />I have AutoCAD 2010. i have a problem with my ltscale changing in model space after I set it to 1. It keeps going back to .4 every time I go to paper space and then come back to Model space.&nbsp;]]>
   <pubDate>Fri, 18 Mar 2011 15:03:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5501&amp;PID=14126&amp;title=ltscale-keeps-changing#14126</guid>
