  <title>CAD Forum discussion (EN) : ARIAL FONT PROBLEM</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : ARIAL FONT PROBLEM]]></description>
  <pubDate>Fri, 02 Oct 2026 13:05:35 +0000</pubDate>
  <lastBuildDate>Thu, 30 Jun 2011 10:04:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5526</WebWizForums:feedURL>
   <title><![CDATA[ARIAL FONT PROBLEM : Thank you Jone Connor for you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=16013&amp;title=arial-font-problem#16013</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=199223">lyssagale12</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 30.Jun.2011 at 10:04<br /><br />Thank you Jone Connor for you solutions !!!<br><br><br>Lyssa Gale<br><a href="http://www.allyourfonts.com/" target="_blank" rel="nofollow">Language Fonts</a><br><br><br><br>   ]]>
   <pubDate>Thu, 30 Jun 2011 10:04:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=16013&amp;title=arial-font-problem#16013</guid>
   <title><![CDATA[ARIAL FONT PROBLEM :   adeelcad wrote:yes sir......................]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14283&amp;title=arial-font-problem#14283</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 23.Mar.2011 at 12:30<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by adeelcad" alt="Originally posted by adeelcad" style="vertical-align: text-bottom;" /> <strong>adeelcad wrote:</strong><br /><br />yes sir................... <DIV>&nbsp;</DIV><DIV>all dimensions are changed..........</DIV><DIV>&nbsp;</DIV><DIV>thank you very much sirrrrrrrr.......</DIV></td></tr></table> <DIV></DIV><DIV></DIV>.<DIV>Glad to hear it.&nbsp; Next time though try sticking to one thread rather than starting two threads on the same subject.&nbsp; It makes it a lot easier to follow.&nbsp; :)</DIV>]]>
   <pubDate>Wed, 23 Mar 2011 12:30:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14283&amp;title=arial-font-problem#14283</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : yes sir...................  all...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14281&amp;title=arial-font-problem#14281</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=176075">adeelcad</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 23.Mar.2011 at 12:18<br /><br />yes sir...................<DIV>&nbsp;</DIV><DIV>all dimensions are changed..........</DIV><DIV>&nbsp;</DIV><DIV>thank you very much sirrrrrrrr.......</DIV>]]>
   <pubDate>Wed, 23 Mar 2011 12:18:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14281&amp;title=arial-font-problem#14281</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : Try these macros then: http:/...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14278&amp;title=arial-font-problem#14278</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 23.Mar.2011 at 11:10<br /><br /><P>Try these macros then:</P><DIV><a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=872" target="_blank">http://www.cadforum.cz/cadforum_en/qaID.asp?tip=872</A></DIV>]]>
   <pubDate>Wed, 23 Mar 2011 11:10:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14278&amp;title=arial-font-problem#14278</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : i can apply change command but...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14273&amp;title=arial-font-problem#14273</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=176075">adeelcad</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 23.Mar.2011 at 10:54<br /><br />i can apply change command but dimension text are not changed.]]>
   <pubDate>Wed, 23 Mar 2011 10:54:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14273&amp;title=arial-font-problem#14273</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : Try using the old CHANGE command....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14270&amp;title=arial-font-problem#14270</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 23.Mar.2011 at 10:48<br /><br /><P>Try using the old CHANGE command.&nbsp; The option you need to use is called ELEVATION.</P>]]>
   <pubDate>Wed, 23 Mar 2011 10:48:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14270&amp;title=arial-font-problem#14270</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : i can check but my problem is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14266&amp;title=arial-font-problem#14266</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=176075">adeelcad</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 23.Mar.2011 at 07:25<br /><br />i can check but my problem is not solve. kindly any other solution.]]>
   <pubDate>Wed, 23 Mar 2011 07:25:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14266&amp;title=arial-font-problem#14266</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : Read this. It might be of some...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14217&amp;title=arial-font-problem#14217</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 22.Mar.2011 at 10:47<br /><br />Read this.&nbsp; It might be of some use.<DIV>&nbsp;</DIV><DIV><a href="http://www.cadforum.cz/forum_en/forum_posts.asp?TID=5484&PID=14055#14055" target="_blank">http://www.cadforum.cz/forum_en/forum_posts.asp?TID=5484&amp;PID=14055#14055</A></DIV>]]>
   <pubDate>Tue, 22 Mar 2011 10:47:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14217&amp;title=arial-font-problem#14217</guid>
   <title><![CDATA[ARIAL FONT PROBLEM : Hi, i m using autocad 2008. i...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14211&amp;title=arial-font-problem#14211</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=176075">adeelcad</a><br /><strong>Subject:</strong> 5526<br /><strong>Posted:</strong> 22.Mar.2011 at 07:42<br /><br /><P>Hi,</P><P>i m using autocad 2008. i m using pdf-xchange 3 here is some problem to make a pdf. i m use arial font.<BR>some text and dimensions show good but some text and dimensions show bold.<BR>i use flatten command all text show good but dimensions are not changed.<BR>plese advice me what can i do.</P><DIV></DIV><DIV>Regards,</DIV><DIV>Adeel</DIV>]]>
   <pubDate>Tue, 22 Mar 2011 07:42:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5526&amp;PID=14211&amp;title=arial-font-problem#14211</guid>
