  <title>CAD Forum discussion (EN) : menu transparancy</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : menu transparancy]]></description>
  <pubDate>Thu, 22 Oct 2026 00:00:01 +0000</pubDate>
  <lastBuildDate>Fri, 08 Apr 2011 00:10:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5635</WebWizForums:feedURL>
   <title><![CDATA[menu transparancy : Is there any chance it might be...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14665&amp;title=menu-transparancy#14665</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5635<br /><strong>Posted:</strong> 08.Apr.2011 at 00:10<br /><br />Is there any chance it might be a graphics-related problem?&nbsp; Did you have a recent change of drivers?]]>
   <pubDate>Fri, 08 Apr 2011 00:10:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14665&amp;title=menu-transparancy#14665</guid>
   <title><![CDATA[menu transparancy : Thank you RMCGARRIE. I tried both...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14643&amp;title=menu-transparancy#14643</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=180541">RCSLA</a><br /><strong>Subject:</strong> 5635<br /><strong>Posted:</strong> 07.Apr.2011 at 17:00<br /><br />Thank you RMCGARRIE. I tried both of your suggestions but it did not change the transparency of the drop-down menu. Is ther another solution?<br />]]>
   <pubDate>Thu, 07 Apr 2011 17:00:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14643&amp;title=menu-transparancy#14643</guid>
   <title><![CDATA[menu transparancy : got to options&amp;gt;display&amp;gt;  click...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14574&amp;title=menu-transparancy#14574</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=174194">RMCGARRIE</a><br /><strong>Subject:</strong> 5635<br /><strong>Posted:</strong> 05.Apr.2011 at 12:12<br /><br />got to options&gt;display&gt;<br /><br />click on the colors box which brings up the "drawing window colors display". in the "interface element" list there is a header called "drafting tool tip background"<br /><br />either change this to white or a colour that suites your 2d model space colour. <br /><br />if this fails try a restore classic colors<br /><br />hope that helps]]>
   <pubDate>Tue, 05 Apr 2011 12:12:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14574&amp;title=menu-transparancy#14574</guid>
   <title><![CDATA[menu transparancy : I am using AutoCad2010. Somehow...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14528&amp;title=menu-transparancy#14528</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=180541">RCSLA</a><br /><strong>Subject:</strong> 5635<br /><strong>Posted:</strong> 01.Apr.2011 at 22:59<br /><br />I am using AutoCad2010. Somehow I inadvertently did something that makes dropdown info transparent; for instance, if I use the “measure” command the window that opens with the “distances” is so transparent that depending on what’s on the plan background it’s almost impossible to read. How do I get rid of the transparency?]]>
   <pubDate>Fri, 01 Apr 2011 22:59:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5635&amp;PID=14528&amp;title=menu-transparancy#14528</guid>
