  <title>CAD Forum discussion (EN) : copying layers</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : copying layers]]></description>
  <pubDate>Tue, 27 Oct 2026 01:41:35 +0000</pubDate>
  <lastBuildDate>Wed, 06 Apr 2011 02:05:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5648</WebWizForums:feedURL>
   <title><![CDATA[copying layers : Hi Alanjit, Thanks.&amp;amp; regds...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14599&amp;title=copying-layers#14599</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=146512">Joferna</a><br /><strong>Subject:</strong> 5648<br /><strong>Posted:</strong> 06.Apr.2011 at 02:05<br /><br /><P>Hi Alanjit,</P><DIV>Thanks.&amp; regds&nbsp;&nbsp; - Joferna </DIV>]]>
   <pubDate>Wed, 06 Apr 2011 02:05:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14599&amp;title=copying-layers#14599</guid>
   <title><![CDATA[copying layers : Hi john, works beautiful-   Thans...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14598&amp;title=copying-layers#14598</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=146512">Joferna</a><br /><strong>Subject:</strong> 5648<br /><strong>Posted:</strong> 06.Apr.2011 at 02:02<br /><br /><P>Hi john,</P><DIV>works beautiful-&nbsp; </DIV><DIV>&nbsp;</DIV><DIV>Thans &amp; Regds&nbsp;&nbsp;- Joferna</DIV>]]>
   <pubDate>Wed, 06 Apr 2011 02:02:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14598&amp;title=copying-layers#14598</guid>
   <title><![CDATA[copying layers :    John Connor wrote:Use the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14581&amp;title=copying-layers#14581</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=45586">alanjt</a><br /><strong>Subject:</strong> 5648<br /><strong>Posted:</strong> 05.Apr.2011 at 14:24<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />Use the <strong>Copy objects to new layer </strong>command.&nbsp; Look under <strong>Format</strong> on your drop-down Menu Bar at the top of your screen.&nbsp; Then select <strong>Layer Tools</strong>.&nbsp; The option will be listed on the fly-out menu.</td></tr></table>or type <b>COPYTOLAYER</b>.<br>]]>
   <pubDate>Tue, 05 Apr 2011 14:24:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14581&amp;title=copying-layers#14581</guid>
   <title><![CDATA[copying layers : Use the Copy objects to new layer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14575&amp;title=copying-layers#14575</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5648<br /><strong>Posted:</strong> 05.Apr.2011 at 12:16<br /><br />Use the <strong>Copy objects to new layer </strong>command.&nbsp; Look under <strong>Format</strong> on your drop-down Menu Bar at the top of your screen.&nbsp; Then select <strong>Layer Tools</strong>.&nbsp; The option will be listed on the fly-out menu.<span style="font-size:10px"><br /><br />Edited by John Connor - 05.Apr.2011 at 12:18</span>]]>
   <pubDate>Tue, 05 Apr 2011 12:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14575&amp;title=copying-layers#14575</guid>
   <title><![CDATA[copying layers : I did a drawing using 5 layers...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14563&amp;title=copying-layers#14563</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=146512">Joferna</a><br /><strong>Subject:</strong> 5648<br /><strong>Posted:</strong> 04.Apr.2011 at 23:54<br /><br /><P>I&nbsp; did a drawing using 5 layers&nbsp;&nbsp; and&nbsp; I realised that if I transfer some objects of&nbsp;a layer say&nbsp;layer 1&nbsp;in the&nbsp;drawing into another layer say layer 2&nbsp;of the same drawing&nbsp;,&nbsp;I lose&nbsp; those objects from layer 1.&nbsp; Is there some&nbsp;&nbsp; way to copy those objects back into layer&nbsp;1&nbsp; without losing them in layer 2.&nbsp;?&nbsp;&nbsp;&nbsp;</P>]]>
   <pubDate>Mon, 04 Apr 2011 23:54:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5648&amp;PID=14563&amp;title=copying-layers#14563</guid>
