  <title>CAD Forum discussion (EN) : Dimension</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Dimension]]></description>
  <pubDate>Wed, 28 Oct 2026 20:18:57 +0000</pubDate>
  <lastBuildDate>Thu, 14 Apr 2011 17:59:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5680</WebWizForums:feedURL>
   <title><![CDATA[Dimension :    Prasanna Achar wrote:U can...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14739&amp;title=dimension#14739</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=45586">alanjt</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 14.Apr.2011 at 17:59<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Prasanna Achar" alt="Originally posted by Prasanna Achar" style="vertical-align: text-bottom;" /> <strong>Prasanna Achar wrote:</strong><br /><br /><p>U can get solution by on/off the Supress trailling zeros in&nbsp;Primary Units tab. Work on that &amp; come back.</p></td></tr></table>AKA: the <b>DIMZIN </b>variable.<br>]]>
   <pubDate>Thu, 14 Apr 2011 17:59:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14739&amp;title=dimension#14739</guid>
   <title><![CDATA[Dimension : U can get solution by on/off the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14725&amp;title=dimension#14725</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=162727">Prasanna Achar</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 14.Apr.2011 at 06:38<br /><br /><P>U can get solution by on/off the Supress trailling zeros in&nbsp;Primary Units tab. Work on that &amp; come back.</P>]]>
   <pubDate>Thu, 14 Apr 2011 06:38:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14725&amp;title=dimension#14725</guid>
   <title><![CDATA[Dimension : I want dim have number 0 in primary...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14704&amp;title=dimension#14704</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=183105">camtulan</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 12.Apr.2011 at 04:47<br /><br />I want dim have number 0 in primary unit don't display, only display primary unit which value not equal zero.Example, one line have long is 2.0 m will display only 2 , but one line other have long is 2.5 m will display 2.5.? <br>Thanks!<br>]]>
   <pubDate>Tue, 12 Apr 2011 04:47:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14704&amp;title=dimension#14704</guid>
   <title><![CDATA[Dimension : I thought you were working in...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14700&amp;title=dimension#14700</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 11.Apr.2011 at 12:30<br /><br /><P>I thought you were working in a layout.&nbsp; Why are you asking about setting a scale?</P><DIV>Check you DimStyle &gt; Modify &gt; Primary Units tab.&nbsp; There is a Scale Factor&nbsp;option there.</DIV><DIV>&nbsp;</DIV><DIV>And on the Fit tab there is a scaling option where it says Scale for dimension features &gt; Use overall scale of.</DIV><span style="font-size:10px"><br /><br />Edited by John Connor - 11.Apr.2011 at 12:32</span>]]>
   <pubDate>Mon, 11 Apr 2011 12:30:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14700&amp;title=dimension#14700</guid>
   <title><![CDATA[Dimension : thanks for quick response.how...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14699&amp;title=dimension#14699</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 11.Apr.2011 at 12:11<br /><br />thanks for quick response.how i set there different veriable scale setting and whats standrend there, for exmple ....Text hight, arrow hight, offset or other setting according to sacle.have you any method setting according to sacle]]>
   <pubDate>Mon, 11 Apr 2011 12:11:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14699&amp;title=dimension#14699</guid>
   <title><![CDATA[Dimension : Use the DimStyle command to set...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14696&amp;title=dimension#14696</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 11.Apr.2011 at 11:48<br /><br />Use the DimStyle command to set the different dimension variables.&nbsp; If you are dimensioning in a layout then you should be using a scale of 1:1.&nbsp; Only your viewports are assigned a scale.]]>
   <pubDate>Mon, 11 Apr 2011 11:48:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14696&amp;title=dimension#14696</guid>
   <title><![CDATA[Dimension : Hiany one tell me about the dimension...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14694&amp;title=dimension#14694</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 5680<br /><strong>Posted:</strong> 11.Apr.2011 at 11:22<br /><br />Hi<br>any one tell me about the dimension setting, over scale and dimensions to layout.where we set arrow size,text size,etc and adjust on different scale.in mm or foot.<br><br>]]>
   <pubDate>Mon, 11 Apr 2011 11:22:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5680&amp;PID=14694&amp;title=dimension#14694</guid>
