  <title>CAD Forum discussion (EN) : STL TO DXF</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : STL TO DXF]]></description>
  <pubDate>Sat, 01 Aug 2026 16:24:44 +0000</pubDate>
  <lastBuildDate>Tue, 03 May 2011 22:20:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5808</WebWizForums:feedURL>
   <title><![CDATA[STL TO DXF :   STL file is - by its nature...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5808&amp;PID=15055&amp;title=stl-to-dxf#15055</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 5808<br /><strong>Posted:</strong> 03.May.2011 at 22:20<br /><br />STL file is - by its nature - composed by multiple thousands or even hundreds&nbsp;thousands of facets. Such huge number of individual objects is rather hard to process in 3D solid modelers. Make sure you have enough RAM, and preferably a 64-bit version of Inventor.]]>
   <pubDate>Tue, 03 May 2011 22:20:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5808&amp;PID=15055&amp;title=stl-to-dxf#15055</guid>
   <title><![CDATA[STL TO DXF : i tried the stl2dxf converter...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5808&amp;PID=15051&amp;title=stl-to-dxf#15051</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=187150">DIE FAST</a><br /><strong>Subject:</strong> 5808<br /><strong>Posted:</strong> 03.May.2011 at 21:59<br /><br />i tried the stl2dxf converter and it works great , but the problem is the STL file was 7.86&nbsp;M and it comes 66.1 M after DXF conversion. It takes 1:45 hour just for opening&nbsp;the file&nbsp;with inventor and about 10 second lag for every fonction in the drawing .<DIV>&nbsp;</DIV><DIV>Does anyone have a solution to get this kind of file smaller or easyer to work with ?</DIV><DIV>&nbsp;</DIV><DIV>Thanks ! </DIV><DIV>&nbsp;</DIV><DIV>Ben&nbsp;&nbsp;</DIV>]]>
   <pubDate>Tue, 03 May 2011 21:59:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5808&amp;PID=15051&amp;title=stl-to-dxf#15051</guid>
