  <title>CAD Forum discussion (EN) : Angular Dimensions in Inventor 2011</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : Angular Dimensions in Inventor 2011]]></description>
  <pubDate>Wed, 29 Jul 2026 00:14:50 +0000</pubDate>
  <lastBuildDate>Fri, 20 May 2011 20:39:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5930</WebWizForums:feedURL>
   <title><![CDATA[Angular Dimensions in Inventor 2011 : No problem man, dont be a stranger...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15427&amp;title=angular-dimensions-in-inventor-2011#15427</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=61756">tulip3D</a><br /><strong>Subject:</strong> 5930<br /><strong>Posted:</strong> 20.May.2011 at 20:39<br /><br />No problem man, dont be a stranger to the site!!]]>
   <pubDate>Fri, 20 May 2011 20:39:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15427&amp;title=angular-dimensions-in-inventor-2011#15427</guid>
   <title><![CDATA[Angular Dimensions in Inventor 2011 : THANKS!!!! tHAT WORKED!!! ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15424&amp;title=angular-dimensions-in-inventor-2011#15424</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=174648">caddan</a><br /><strong>Subject:</strong> 5930<br /><strong>Posted:</strong> 20.May.2011 at 20:30<br /><br />THANKS!!!! &nbsp;tHAT WORKED!!!]]>
   <pubDate>Fri, 20 May 2011 20:30:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15424&amp;title=angular-dimensions-in-inventor-2011#15424</guid>
   <title><![CDATA[Angular Dimensions in Inventor 2011 : CLICK DIMENSION. SELECT YOUR...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15423&amp;title=angular-dimensions-in-inventor-2011#15423</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=61756">tulip3D</a><br /><strong>Subject:</strong> 5930<br /><strong>Posted:</strong> 20.May.2011 at 20:26<br /><br />CLICK DIMENSION.<DIV>SELECT YOUR LINES AND FORM YOUR DIM.</DIV><DIV>THEN LEFT CLICK WHILE STILL IN THE DIM COMMAND.</DIV><DIV>SELECT OPTIONS.</DIV><DIV>SELECT OPPOSITE ANGLE...SORRY FOR 'YELLING' LOL friggin caps lock</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Fri, 20 May 2011 20:26:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15423&amp;title=angular-dimensions-in-inventor-2011#15423</guid>
   <title><![CDATA[Angular Dimensions in Inventor 2011 : Does anyone know how I can dimension...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15422&amp;title=angular-dimensions-in-inventor-2011#15422</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=174648">caddan</a><br /><strong>Subject:</strong> 5930<br /><strong>Posted:</strong> 20.May.2011 at 19:15<br /><br />Does anyone know how I can dimension 2 lines that are over 180*?]]>
   <pubDate>Fri, 20 May 2011 19:15:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5930&amp;PID=15422&amp;title=angular-dimensions-in-inventor-2011#15422</guid>
