  <title>CAD Forum discussion (EN) : pipe joining?</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : pipe joining?]]></description>
  <pubDate>Sat, 05 Sep 2026 06:12:08 +0000</pubDate>
  <lastBuildDate>Wed, 25 May 2011 11:49:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5950</WebWizForums:feedURL>
   <title><![CDATA[pipe joining? : It would be much better if you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5950&amp;PID=15467&amp;title=pipe-joining#15467</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 5950<br /><strong>Posted:</strong> 25.May.2011 at 11:49<br /><br />It would be much better if you posted a drawing file or, at the very least, an image.&nbsp; A picture is worth a thousand mixed up words.]]>
   <pubDate>Wed, 25 May 2011 11:49:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5950&amp;PID=15467&amp;title=pipe-joining#15467</guid>
   <title><![CDATA[pipe joining? : Hi. Im using autocad 2010 to draw...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5950&amp;PID=15466&amp;title=pipe-joining#15466</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191867">kelvin.loh</a><br /><strong>Subject:</strong> 5950<br /><strong>Posted:</strong> 25.May.2011 at 04:06<br /><br />Hi. Im using autocad 2010 to draw 3d cylinders shaped like this <DIV>&nbsp;</DIV><DIV>I ( I L I</DIV><DIV>&nbsp;</DIV><DIV>i want to join I to ( so i can get something like J&nbsp;&nbsp;but because im amateur i drew&nbsp; those pipes in different dimension view and they're position all around the place and angles to the point that i cant find the correct angle to turn I so that it can fit into ( .</DIV><DIV>&nbsp;</DIV><DIV>Is there an easier way to fit them without using rotation?</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Wed, 25 May 2011 04:06:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5950&amp;PID=15466&amp;title=pipe-joining#15466</guid>
