  <title>CAD Forum discussion (EN) : Formula in block??</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Formula in block??]]></description>
  <pubDate>Fri, 04 Sep 2026 23:33:40 +0000</pubDate>
  <lastBuildDate>Wed, 01 Jun 2011 15:06:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=5994</WebWizForums:feedURL>
   <title><![CDATA[Formula in block?? : That&amp;#039;s not what I was referring...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5994&amp;PID=15559&amp;title=formula-in-block#15559</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=31784">pmm3434</a><br /><strong>Subject:</strong> 5994<br /><strong>Posted:</strong> 01.Jun.2011 at 15:06<br /><br />That's not what I was referring to. For example, I would like to put 12.5 into a block and be able to convert it to 12'-6".&nbsp;]]>
   <pubDate>Wed, 01 Jun 2011 15:06:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5994&amp;PID=15559&amp;title=formula-in-block#15559</guid>
   <title><![CDATA[Formula in block?? : It is possible to insert a bloc...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5994&amp;PID=15558&amp;title=formula-in-block#15558</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 5994<br /><strong>Posted:</strong> 01.Jun.2011 at 12:54<br /><br />It is possible to insert a bloc without unit problems if you set the DDUNITS parameters in each file you create.<DIV>DDUNITS command will let you set an "INSERTION SCALE".</DIV><DIV>You may find problems if&nbsp;you haven't&nbsp;set appropriatly the DDUNITS parameters in the file in wich you are working and in the file that you will insert.</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Wed, 01 Jun 2011 12:54:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5994&amp;PID=15558&amp;title=formula-in-block#15558</guid>
   <title><![CDATA[Formula in block?? : Is it possible to create a block...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5994&amp;PID=15551&amp;title=formula-in-block#15551</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=31784">pmm3434</a><br /><strong>Subject:</strong> 5994<br /><strong>Posted:</strong> 01.Jun.2011 at 00:19<br /><br />Is it possible to create a block that will convert decimal to architectural units? <DIV>&nbsp;</DIV><DIV>We are using blocks for all of our existing elevations and would like to convert them (or have the option) to architectural once the info has been inserted into the field. I'm thinking of having&nbsp;a dynamic block w/ a decimal or architectural feature. </DIV><DIV>&nbsp;</DIV><DIV>Any help / thought would be appreciated. Thanks!</DIV>]]>
   <pubDate>Wed, 01 Jun 2011 00:19:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=5994&amp;PID=15551&amp;title=formula-in-block#15551</guid>
