  <title>CAD Forum discussion (EN) : Data incorrect..</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Data incorrect..]]></description>
  <pubDate>Wed, 28 Oct 2026 00:59:08 +0000</pubDate>
  <lastBuildDate>Thu, 23 Jun 2011 03:45:42 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6066</WebWizForums:feedURL>
   <title><![CDATA[Data incorrect.. : Yeah,I had this issue in the past...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15870&amp;title=data-incorrect#15870</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=150189">edwinprakoso</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 23.Jun.2011 at 03:45<br /><br />Yeah,<div>I had this issue in the past too.</div><div>After I move it as close as possible to 0,0.. the problem solved.</div><div><br></div>]]>
   <pubDate>Thu, 23 Jun 2011 03:45:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15870&amp;title=data-incorrect#15870</guid>
   <title><![CDATA[Data incorrect.. : Are your coordinates large, such...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15798&amp;title=data-incorrect#15798</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 17.Jun.2011 at 09:00<br /><br />Are your coordinates large, such as over 1,000,000?<DIV>AutoCAD is notoriosly lousy at accurate calculations when objects have&nbsp;large&nbsp;coordinate values.</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Fri, 17 Jun 2011 09:00:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15798&amp;title=data-incorrect#15798</guid>
   <title><![CDATA[Data incorrect.. : A government deficit reduction...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15771&amp;title=data-incorrect#15771</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=61756">tulip3D</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 15.Jun.2011 at 14:04<br /><br /><P>A government deficit reduction plan! <img src="http://www.cadforum.cz/forum_en/smileys/smiley36.gif" height="17" width="17" border="0" align="absmiddle" alt="LOL" /></P>]]>
   <pubDate>Wed, 15 Jun 2011 14:04:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15771&amp;title=data-incorrect#15771</guid>
   <title><![CDATA[Data incorrect.. : What are you building that you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15769&amp;title=data-incorrect#15769</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 15.Jun.2011 at 12:31<br /><br />What are you building that you need that level of precision in your dimensions?]]>
   <pubDate>Wed, 15 Jun 2011 12:31:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15769&amp;title=data-incorrect#15769</guid>
   <title><![CDATA[Data incorrect.. :   John Connor wrote:What version...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15768&amp;title=data-incorrect#15768</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7984">vaa13</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 15.Jun.2011 at 09:47<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />What version of AutoCAD are you using?</td></tr></table> <DIV>&nbsp;</DIV><DIV>i am using 2011 now..</DIV><DIV>but this problem was found pervious version ie: 2004 2008 and 2010^^</DIV>]]>
   <pubDate>Wed, 15 Jun 2011 09:47:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15768&amp;title=data-incorrect#15768</guid>
   <title><![CDATA[Data incorrect.. : LOL reduce your precision to something...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15723&amp;title=data-incorrect#15723</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=61756">tulip3D</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 13.Jun.2011 at 22:38<br /><br /><P>LOL reduce your precision to something two decimal places larger. That should solve it! </P>]]>
   <pubDate>Mon, 13 Jun 2011 22:38:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15723&amp;title=data-incorrect#15723</guid>
   <title><![CDATA[Data incorrect.. : What version of AutoCAD are you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15709&amp;title=data-incorrect#15709</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 13.Jun.2011 at 12:08<br /><br />What version of AutoCAD are you using?]]>
   <pubDate>Mon, 13 Jun 2011 12:08:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15709&amp;title=data-incorrect#15709</guid>
   <title><![CDATA[Data incorrect.. : hi all,  please help me .. since...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15708&amp;title=data-incorrect#15708</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7984">vaa13</a><br /><strong>Subject:</strong> 6066<br /><strong>Posted:</strong> 13.Jun.2011 at 11:16<br /><br /><P>hi all,</P><DIV>&nbsp;</DIV><DIV>please help me .. since i have a dwg which .. when i draw a 10 by 10 rectenangle..it seem ok ie: area = 100 perimeter is 40..etc...</DIV><DIV>&nbsp;</DIV><DIV>and i copy it.. it still ok.. but, ehn i rotate it.. ie by 15deg.</DIV><DIV>then list it .. the area is 100.00000012 and perimeter is 40.00000015...etc..</DIV><DIV>&nbsp;</DIV><DIV>anyone know what happening in it.. ??</DIV><DIV>&nbsp;</DIV><DIV>p.s. those in world UCS.. and elev=0...</DIV>]]>
   <pubDate>Mon, 13 Jun 2011 11:16:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6066&amp;PID=15708&amp;title=data-incorrect#15708</guid>
