  <title>CAD Forum discussion (EN) : Not enough free RAM...</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Not enough free RAM...]]></description>
  <pubDate>Sun, 01 Nov 2026 11:51:53 +0000</pubDate>
  <lastBuildDate>Tue, 21 Jun 2011 12:57:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6109</WebWizForums:feedURL>
   <title><![CDATA[Not enough free RAM... : Hide should normally have enough...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15853&amp;title=not-enough-free-ram#15853</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6109<br /><strong>Posted:</strong> 21.Jun.2011 at 12:57<br /><br />Hide should normally have enough memory in either setting. Toggling its value switches to a completely different hide-algorithm which may solve the memory problem (because it sounds like&nbsp;a software bug).]]>
   <pubDate>Tue, 21 Jun 2011 12:57:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15853&amp;title=not-enough-free-ram#15853</guid>
   <title><![CDATA[Not enough free RAM... :  Re: HIDEPRECISION.The default...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15852&amp;title=not-enough-free-ram#15852</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6109<br /><strong>Posted:</strong> 21.Jun.2011 at 12:14<br /><br />Re: HIDEPRECISION.<br><br>The default setting for this variable is "0" meaning  less memory needed, less calculation time consumed, but also less precision.&nbsp; Unless you intentionally reset it to "1" to use more memory.&nbsp; Did you?<br><br><br><span style="font-size:10px"><br /><br />Edited by John Connor - 21.Jun.2011 at 12:18</span>]]>
   <pubDate>Tue, 21 Jun 2011 12:14:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15852&amp;title=not-enough-free-ram#15852</guid>
   <title><![CDATA[Not enough free RAM... : Just curious.Is this a 32-bit...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15851&amp;title=not-enough-free-ram#15851</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6109<br /><strong>Posted:</strong> 21.Jun.2011 at 12:07<br /><br />Just curious.<br><br>Is this a 32-bit or 64-bit system?<br><br>What version of Windows are you running?&nbsp; XP, Win7, other?<br>]]>
   <pubDate>Tue, 21 Jun 2011 12:07:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15851&amp;title=not-enough-free-ram#15851</guid>
   <title><![CDATA[Not enough free RAM... : Try to switch the HIDEPRECISION...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15849&amp;title=not-enough-free-ram#15849</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6109<br /><strong>Posted:</strong> 21.Jun.2011 at 08:24<br /><br />Try to switch the &#091;VAR&#093;HIDEPRECISION&#091;/VAR&#093; variable.]]>
   <pubDate>Tue, 21 Jun 2011 08:24:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15849&amp;title=not-enough-free-ram#15849</guid>
   <title><![CDATA[Not enough free RAM... : Haven&amp;#039;t seen a message like...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15847&amp;title=not-enough-free-ram#15847</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6109<br /><strong>Posted:</strong> 20.Jun.2011 at 23:47<br /><br />Haven't seen a message like that since the DOS days and early AutoCAD.<br><br>What else are you running in the background while using AutoCAD?<br><br>How many sessions of AutoCAD do you run at one time?<br><br>When did the problem first occur?<br><br>What have you been tweaking or tinkering with on your computer?<br>]]>
   <pubDate>Mon, 20 Jun 2011 23:47:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15847&amp;title=not-enough-free-ram#15847</guid>
   <title><![CDATA[Not enough free RAM... : Hello guys,I&amp;#039;m having some...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15844&amp;title=not-enough-free-ram#15844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=199860">RenatoP</a><br /><strong>Subject:</strong> 6109<br /><strong>Posted:</strong> 20.Jun.2011 at 22:18<br /><br />Hello guys,<br><br>I'm having some issues when i'm hiding lines on my AutoCAD 2011.<br>I receive this message:<br><br>"Not enough free RAM for HIDE--some lines will be hidden incorrectly."<br><br>I don't know why this is happening.<br><br>Here are my PC specs:<br><br>Quad Core 2.22Ghz<br>4Gb RAM<br>500 GB HD<br>ATI RADEON HD 4300<br>]]>
   <pubDate>Mon, 20 Jun 2011 22:18:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6109&amp;PID=15844&amp;title=not-enough-free-ram#15844</guid>
