  <title>CAD Forum discussion (EN) : Autocad 2004 error 1.248.1001</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Autocad 2004 error 1.248.1001]]></description>
  <pubDate>Tue, 03 Nov 2026 03:27:19 +0000</pubDate>
  <lastBuildDate>Fri, 24 Jun 2011 17:35:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6135</WebWizForums:feedURL>
   <title><![CDATA[Autocad 2004 error 1.248.1001 : Read this: http://www.sevenfor...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15926&amp;title=autocad-2004-error-12481001#15926</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 17:35<br /><br />Read this: http://www.sevenforums.com/tutorials/8247-windows-xp-mode-install-setup.html]]>
   <pubDate>Fri, 24 Jun 2011 17:35:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15926&amp;title=autocad-2004-error-12481001#15926</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 :   windows 7 home ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15925&amp;title=autocad-2004-error-12481001#15925</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200577">CW123</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 17:19<br /><br />windows 7 home]]>
   <pubDate>Fri, 24 Jun 2011 17:19:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15925&amp;title=autocad-2004-error-12481001#15925</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 : Yes, you can run it in XP compatibility...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15919&amp;title=autocad-2004-error-12481001#15919</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 15:40<br /><br />Yes, you can run it in XP compatibility mode.]]>
   <pubDate>Fri, 24 Jun 2011 15:40:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15919&amp;title=autocad-2004-error-12481001#15919</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 : I know that AutoCAD 2004 is not...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15917&amp;title=autocad-2004-error-12481001#15917</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 15:27<br /><br />I know that AutoCAD 2004 is not supported under Windows 7 however I can assure you I have it loaded on my computer.<br><br>CW123: What VERSION of Win7 are you using?<br>]]>
   <pubDate>Fri, 24 Jun 2011 15:27:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15917&amp;title=autocad-2004-error-12481001#15917</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 :   can I not run in compatibility...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15916&amp;title=autocad-2004-error-12481001#15916</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200577">CW123</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 15:24<br /><br />can I not run in compatibility mode?]]>
   <pubDate>Fri, 24 Jun 2011 15:24:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15916&amp;title=autocad-2004-error-12481001#15916</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 : AutoCAD 2004 is not supported...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15915&amp;title=autocad-2004-error-12481001#15915</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 15:20<br /><br />AutoCAD 2004 is not supported under Windows 7. Either upgrade your AutoCAD (to the current version 2012), or downgrade your operating system (to WinXP - which was the OS for ACAD 2004).]]>
   <pubDate>Fri, 24 Jun 2011 15:20:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15915&amp;title=autocad-2004-error-12481001#15915</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 :   I am running Windows 7 (64bits)....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15913&amp;title=autocad-2004-error-12481001#15913</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200577">CW123</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 15:12<br /><br />I am running Windows 7 (64bits).&nbsp; I try to load the program and halfway through I get the error message - nothing works.&nbsp; What are my alternatives since I cann't download the program?]]>
   <pubDate>Fri, 24 Jun 2011 15:12:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15913&amp;title=autocad-2004-error-12481001#15913</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 : Is this a 64-bit version of Windows...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15898&amp;title=autocad-2004-error-12481001#15898</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 12:05<br /><br />Is this a 64-bit version of Windows 7 or a 32-bit version?<br><br>Because of its age I'm confident that AutoCAD 2004 is 32-bit.<br><br>What version of Windows 7 are you running?<br><br>You might have to try running AutoCAD 2004 in XP compatibility mode.<br><br>I have 2004 (32-bit) running under Win7 Ultimate (64-bit) strictly as an experiment.&nbsp; In my day-to-day use I am running 2011 (64-bit).&nbsp; I also have 2007 (32-bit) and 2010 (32-bit) loaded.<br>]]>
   <pubDate>Fri, 24 Jun 2011 12:05:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15898&amp;title=autocad-2004-error-12481001#15898</guid>
   <title><![CDATA[Autocad 2004 error 1.248.1001 :   can anyone tell me what this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15894&amp;title=autocad-2004-error-12481001#15894</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200577">CW123</a><br /><strong>Subject:</strong> 6135<br /><strong>Posted:</strong> 24.Jun.2011 at 04:41<br /><br />can anyone tell me what this is and how do I resolve this error.&nbsp; I am trying to install autocad 2004 on windows 7 and this message pops up...]]>
   <pubDate>Fri, 24 Jun 2011 04:41:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6135&amp;PID=15894&amp;title=autocad-2004-error-12481001#15894</guid>
