  <title>CAD Forum discussion (EN) : Exploding Text AutoCAD 2012 Mechanical</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Exploding Text AutoCAD 2012 Mechanical]]></description>
  <pubDate>Sun, 06 Sep 2026 09:49:45 +0000</pubDate>
  <lastBuildDate>Mon, 11 Jul 2011 11:52:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6235</WebWizForums:feedURL>
   <title><![CDATA[Exploding Text AutoCAD 2012 Mechanical : Did the command work at one time...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6235&amp;PID=16132&amp;title=exploding-text-autocad-2012-mechanical#16132</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6235<br /><strong>Posted:</strong> 11.Jul.2011 at 11:52<br /><br />Did the command work at one time then stop functioning?<br><br>Is Express Tools loaded?<br>]]>
   <pubDate>Mon, 11 Jul 2011 11:52:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6235&amp;PID=16132&amp;title=exploding-text-autocad-2012-mechanical#16132</guid>
   <title><![CDATA[Exploding Text AutoCAD 2012 Mechanical : If you&amp;#039;r interrested, I&amp;#039;ve...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6235&amp;PID=16131&amp;title=exploding-text-autocad-2012-mechanical#16131</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 6235<br /><strong>Posted:</strong> 11.Jul.2011 at 07:25<br /><br />If you'r interrested, I've loaded a file with 3D letters and numbers "ABCD.dwg".<DIV>&nbsp;</DIV><DIV>I use it in my 3D drawings that I transfert to "SOLIDWORKS" because in the convertion the texts don't go to "SOLIDWORKS".</DIV><DIV>&nbsp;</DIV><DIV>I think that I've already seen a cad discussion about this and the solution was to save the file ( beware to save a copy and not the original ) to the Release 12 ( to be confirmed ).</DIV>]]>
   <pubDate>Mon, 11 Jul 2011 07:25:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6235&amp;PID=16131&amp;title=exploding-text-autocad-2012-mechanical#16131</guid>
   <title><![CDATA[Exploding Text AutoCAD 2012 Mechanical :   I use to be able to explode...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6235&amp;PID=16125&amp;title=exploding-text-autocad-2012-mechanical#16125</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=203614">fpluce3</a><br /><strong>Subject:</strong> 6235<br /><strong>Posted:</strong> 10.Jul.2011 at 22:38<br /><br />I use to be able to explode text in 2011 but the txtexp command does not work any more,&nbsp; How do you creat 3D solids from text now if you cant explode and push/pull to generate the solid?]]>
   <pubDate>Sun, 10 Jul 2011 22:38:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6235&amp;PID=16125&amp;title=exploding-text-autocad-2012-mechanical#16125</guid>
