  <title>CAD Forum discussion (EN) : Corrdinate</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Corrdinate]]></description>
  <pubDate>Sun, 01 Nov 2026 01:57:18 +0000</pubDate>
  <lastBuildDate>Mon, 29 Aug 2011 16:41:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6497</WebWizForums:feedURL>
   <title><![CDATA[Corrdinate : Unknown user? Does it give you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16841&amp;title=corrdinate#16841</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6497<br /><strong>Posted:</strong> 29.Aug.2011 at 16:41<br /><br />Unknown user?&nbsp; Does it give you the remainder of the information as well?<br><br>WHOHAS<br> "After you select a file, the ownership information is displayed on the command line. The information includes the current user's computer name, login ID, and full name (if available) and the date and time the drawing file was opened."<br>]]>
   <pubDate>Mon, 29 Aug 2011 16:41:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16841&amp;title=corrdinate#16841</guid>
   <title><![CDATA[Corrdinate : i am using 2007 there i put this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16837&amp;title=corrdinate#16837</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 6497<br /><strong>Posted:</strong> 29.Aug.2011 at 12:22<br /><br />i am using 2007 there i put this command and i receive massage....unknown user.]]>
   <pubDate>Mon, 29 Aug 2011 12:22:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16837&amp;title=corrdinate#16837</guid>
   <title><![CDATA[Corrdinate :  To find out who might have a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16825&amp;title=corrdinate#16825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6497<br /><strong>Posted:</strong> 28.Aug.2011 at 13:08<br /><br />To find out who might have a drawing open you can use the WHOHAS command.<br><br>Keeping tighter control on drawings may require the use of AutoDesk Vault or some such similar program.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 28.Aug.2011 at 13:10</span>]]>
   <pubDate>Sun, 28 Aug 2011 13:08:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16825&amp;title=corrdinate#16825</guid>
   <title><![CDATA[Corrdinate : Hiwhich command use for checking,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16820&amp;title=corrdinate#16820</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 6497<br /><strong>Posted:</strong> 28.Aug.2011 at 07:04<br /><br />Hi<div><br></div><div><br></div><div>which command use for checking, dwg is on actual location or moved. because some time draftsman moved form actual location or rotate for work.</div><div>i want to check in short time dwgs the actual location and then i want to work on it through&nbsp;coordinate&nbsp;systum. and whats process of for moved dwg to actual location.</div>]]>
   <pubDate>Sun, 28 Aug 2011 07:04:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6497&amp;PID=16820&amp;title=corrdinate#16820</guid>
