  <title>CAD Forum discussion (EN) : extrude question</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : extrude question]]></description>
  <pubDate>Tue, 29 Sep 2026 16:44:45 +0000</pubDate>
  <lastBuildDate>Wed, 05 Oct 2011 08:52:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6645</WebWizForums:feedURL>
   <title><![CDATA[extrude question : You said that you have a shape...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17300&amp;title=extrude-question#17300</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 6645<br /><strong>Posted:</strong> 05.Oct.2011 at 08:52<br /><br /><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>You said that you have a shape ready to be extruded with “pedit” ( did you really close your shape ? ).<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>You can convert a selection of lines, arcs, ellipses, etc into a closed shape with the command “REGION” that will make you sure that your shape is OK to be extruded that’s to say without lines in double or not jointed etc…<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>Read the Autocad message on the command line : NOT-OK : 0 regions created, OK : 1 ( or X ) regions created.<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>If your region is OK, make sure that the path that you will use is OK for the region to be extruded.<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>Read the error message given by Autocad when trying to extrude your shape.<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>If it says that the shape is impossible to be extruded with a message like : <o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>The lateral<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>curve doesn’t cut the surface it means that your path has radius to little to “bend” your shape :<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>The distance between your path centreline and the external of your shape is giving you the minimum radius.<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>In that case you will have to extrude your shape on paths with extra lengths and “SUBTRACT” or “CHAMFER” the extremities.<o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>Example in the real life : You make a frame with tubes, two possibilities : <o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB" lang=EN-GB>1 – You bend the tubes</P><DIV></SPAN><SPAN style="FONT-FAMILY: Tahoma; COLOR: black; FONT-SIZE: 8.5pt; mso-ansi-: EN-GB; mso-fareast-font-family: 'Times New Roman'; mso-fareast-: FR; mso-bidi-: AR-SA" lang=EN-GB>2 – You cut the tubes with a saw at 45° or other angles ( may be you case )</SPAN></DIV>]]>
   <pubDate>Wed, 05 Oct 2011 08:52:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17300&amp;title=extrude-question#17300</guid>
   <title><![CDATA[extrude question :   Thanks MysterEman ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17294&amp;title=extrude-question#17294</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=212804">jdycady</a><br /><strong>Subject:</strong> 6645<br /><strong>Posted:</strong> 04.Oct.2011 at 19:42<br /><br />Thanks MysterEman]]>
   <pubDate>Tue, 04 Oct 2011 19:42:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17294&amp;title=extrude-question#17294</guid>
   <title><![CDATA[extrude question : First thing you can do is check...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17289&amp;title=extrude-question#17289</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=219443">MysterEman</a><br /><strong>Subject:</strong> 6645<br /><strong>Posted:</strong> 04.Oct.2011 at 16:28<br /><br />First thing you can do is check to make sure that none of your intersections "double back" on themselves creating a Loop. If there are any of these you will have to straighten them out or remake your closed polyline horseshoe shape and then Extrude again.Good luck.<br>]]>
   <pubDate>Tue, 04 Oct 2011 16:28:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17289&amp;title=extrude-question#17289</guid>
   <title><![CDATA[extrude question : You&amp;#039;ll have to post the drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17157&amp;title=extrude-question#17157</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6645<br /><strong>Posted:</strong> 25.Sep.2011 at 02:42<br /><br />You'll have to post the drawing file for anyone to figure out what is wrong and how to fix it.]]>
   <pubDate>Sun, 25 Sep 2011 02:42:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17157&amp;title=extrude-question#17157</guid>
   <title><![CDATA[extrude question :   I have a shape that looks...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17156&amp;title=extrude-question#17156</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=212804">jdycady</a><br /><strong>Subject:</strong> 6645<br /><strong>Posted:</strong> 25.Sep.2011 at 01:41<br /><br />I have a shape that looks like an irregular horseshoe. It took 10 segments to build it. It composed of arcs and straight lines. I pedited the shape and it looks fine and ready for extrusion. My problem is not being able to extrude it. When I type ext it says to select object, when I do I'm supposed to get an option of running down a path, instead I keep getting 1 object removed from selection set. I've redone the drawing&nbsp;over twice with the same results. Any advise would be appreciated.&nbsp; Thanks ]]>
   <pubDate>Sun, 25 Sep 2011 01:41:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6645&amp;PID=17156&amp;title=extrude-question#17156</guid>
