  <title>CAD Forum discussion (EN) : problem with text, dtext, etc.</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : problem with text, dtext, etc.]]></description>
  <pubDate>Wed, 30 Sep 2026 13:18:44 +0000</pubDate>
  <lastBuildDate>Thu, 29 Sep 2011 11:57:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6663</WebWizForums:feedURL>
   <title><![CDATA[problem with text, dtext, etc. : Do you set your text size using...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17223&amp;title=problem-with-text-dtext-etc#17223</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6663<br /><strong>Posted:</strong> 29.Sep.2011 at 11:57<br /><br />Do you set your text size using the STYLE command?<br><br>Are you using annotative scaling?<br>]]>
   <pubDate>Thu, 29 Sep 2011 11:57:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17223&amp;title=problem-with-text-dtext-etc#17223</guid>
   <title><![CDATA[problem with text, dtext, etc. : Thanks for checking back with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17213&amp;title=problem-with-text-dtext-etc#17213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=217990">Sallyq</a><br /><strong>Subject:</strong> 6663<br /><strong>Posted:</strong> 29.Sep.2011 at 01:32<br /><br />Thanks for checking back with me, &nbsp;I discovered my problem. &nbsp;The text was there, it was just very small, so I had to scale it up. &nbsp;I still haven't figured out why when I had set up the text size it is still coming up so small. &nbsp;Evidently I'm not setting it up in the correct place. &nbsp;Any help will be appreciated.]]>
   <pubDate>Thu, 29 Sep 2011 01:32:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17213&amp;title=problem-with-text-dtext-etc#17213</guid>
   <title><![CDATA[problem with text, dtext, etc. : What steps have you taken to determine...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17205&amp;title=problem-with-text-dtext-etc#17205</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6663<br /><strong>Posted:</strong> 28.Sep.2011 at 11:50<br /><br />What steps have you taken to determine the cause of the problem?&nbsp; No sense in giving you suggestions if you've already tried them.]]>
   <pubDate>Wed, 28 Sep 2011 11:50:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17205&amp;title=problem-with-text-dtext-etc#17205</guid>
   <title><![CDATA[problem with text, dtext, etc. : I have been using Autocad for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17199&amp;title=problem-with-text-dtext-etc#17199</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=217990">Sallyq</a><br /><strong>Subject:</strong> 6663<br /><strong>Posted:</strong> 28.Sep.2011 at 00:48<br /><br />I have been using Autocad for 20 years, however, I am new to Civil 3d 2011 and I'm having trouble with the text command. &nbsp;When I type in text or dtext and after I'm through typing my text, it doesn't matter if I hit enter or escape, or whatever, my text disappears. &nbsp;What am I doing wrong?]]>
   <pubDate>Wed, 28 Sep 2011 00:48:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6663&amp;PID=17199&amp;title=problem-with-text-dtext-etc#17199</guid>
