  <title>CAD Forum discussion (EN) : proxy saveAs polyline plinegen</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : proxy saveAs polyline plinegen]]></description>
  <pubDate>Thu, 22 Oct 2026 14:34:44 +0000</pubDate>
  <lastBuildDate>Tue, 22 Apr 2008 13:36:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=667</WebWizForums:feedURL>
   <title><![CDATA[proxy saveAs polyline plinegen : hallo, i have my own object deried...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=667&amp;PID=1718&amp;title=proxy-saveas-polyline-plinegen#1718</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=8720">jpospisil</a><br /><strong>Subject:</strong> 667<br /><strong>Posted:</strong> 22.Apr.2008 at 13:36<br /><br />hallo,<DIV>i have my own object deried from entity</DIV><DIV>it is normally displayed - everithing Ok</DIV><DIV>when autocad is calling saveAs(), i instead of normal calling of worlddraw func.&nbsp;call my own function to participate subEntities</DIV><DIV>there is the problem:</DIV><DIV>when&nbsp;geometry()-&gt; calls polyline()&nbsp;i&nbsp;call AcgiLineTypeEngine::tesselate() to participate polyline of different linetype</DIV><DIV>when i open file without arx initialisation, the proxy entity will appear</DIV><DIV>BUT when i explode this one (polyline as proxy&nbsp;in my case), the exploded object should be the same, but it's not. It has set the "linetype generation" in propertiesBox to off, when i change this flag manually - it's ok</DIV><DIV>how can i change this flag to true during saving proxy gaphics?</DIV><DIV>i tried AcdbDatabase::setPlinegen() but doesn't affect</DIV><DIV>so - proxy drawn by tesselation is ok, but the exploded&nbsp;proxy object has changed the plinegen flag to false (this flag means overflowing of non_continuous linetype over vertexes)</DIV><DIV>would you help me pls?</DIV><DIV>thank you very much</DIV><DIV>jp</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 22 Apr 2008 13:36:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=667&amp;PID=1718&amp;title=proxy-saveas-polyline-plinegen#1718</guid>
