  <title>CAD Forum discussion (EN) : Insert same name Block ?</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Insert same name Block ?]]></description>
  <pubDate>Wed, 28 Oct 2026 09:11:11 +0000</pubDate>
  <lastBuildDate>Wed, 05 Oct 2011 11:51:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6682</WebWizForums:feedURL>
   <title><![CDATA[Insert same name Block ? :     O3ISSA wrote:get cad block...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17304&amp;title=insert-same-name-block#17304</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6682<br /><strong>Posted:</strong> 05.Oct.2011 at 11:51<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by O3ISSA" alt="Originally posted by O3ISSA" style="vertical-align: text-bottom;" /> <strong>O3ISSA wrote:</strong><br /><br />get cad block for boxer on http://archilines.blogspot.com/2011/10/boxer.html<br>or dancing women on http://archilines.blogspot.com/2011/10/women-dance.html<br>or teenager from http://archilines.blogspot.com/2011/10/blog-post.html<br></td></tr></table><br>What do any of these have to do with the original question?&nbsp; Try to stick to the topic at hand.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 05.Oct.2011 at 11:52</span>]]>
   <pubDate>Wed, 05 Oct 2011 11:51:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17304&amp;title=insert-same-name-block#17304</guid>
   <title><![CDATA[Insert same name Block ? : get cad block for boxer on htt...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17296&amp;title=insert-same-name-block#17296</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=219309">O3ISSA</a><br /><strong>Subject:</strong> 6682<br /><strong>Posted:</strong> 05.Oct.2011 at 04:08<br /><br />get cad block for boxer on http://archilines.blogspot.com/2011/10/boxer.html<br>or dancing women on http://archilines.blogspot.com/2011/10/women-dance.html<br>or teenager from http://archilines.blogspot.com/2011/10/blog-post.html<br>]]>
   <pubDate>Wed, 05 Oct 2011 04:08:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17296&amp;title=insert-same-name-block#17296</guid>
   <title><![CDATA[Insert same name Block ? : First, take the block that you&amp;#039;ve...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17288&amp;title=insert-same-name-block#17288</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=212617">twangmaster</a><br /><strong>Subject:</strong> 6682<br /><strong>Posted:</strong> 04.Oct.2011 at 15:17<br /><br />First, take the block that you've edited and want to use in the other drawings and WBLOCK it out to a common directory.&nbsp; Then, in the other drawings that you want to 'redefine' the block in, use the INSERT command, select the block from the files list and say yes when prompted if you want to REDEFINE the block.&nbsp; Or, use the -Insert command, and at the "Enter block name or &#091;?&#093; prompt enter&nbsp;&nbsp; &#091;NAME OF BLOCK&#093;=&#091;NAME OF BLOCK&#093;&nbsp; Acad will respond with "Block "&#091;NAME OF BLOCK&#093; already existings.&nbsp; Redefine it? &#091;Yes/No&#093; &lt;N&gt;:&nbsp; answer Yes.&nbsp; When it asks you for the insertion point, hit escape.&nbsp; Your block has just been redefined to match the one&nbsp; you WBLOCKED to the drive.]]>
   <pubDate>Tue, 04 Oct 2011 15:17:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17288&amp;title=insert-same-name-block#17288</guid>
   <title><![CDATA[Insert same name Block ? :    John Connor wrote:You want...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17259&amp;title=insert-same-name-block#17259</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=218542">Roddo</a><br /><strong>Subject:</strong> 6682<br /><strong>Posted:</strong> 02.Oct.2011 at 03:35<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />You want to be able to have two blocks with the<i> exact same name</i> in one drawing?</td></tr></table><div>&nbsp;</div><div>Thank for you input John, I want to know if there is a way, that you can cut &amp; paste a same name block from one drawing&nbsp;into another drawing and have the existing block updated, instead of being ignored by autocad if the existing block have the same name.</div><div>&nbsp;</div><div>A bit confusion, but as last post, my drawing is divided into small drawings so we can work on seperate components. After the components are finished, we bring copy and past them back to the master assembly. </div><div>&nbsp;</div><div>If i am working alone on the drawing, then there would be no problem. But if someone is taking over my project, and they dont realised that when cut &amp; past blocks with the same name from the component drawing into the master assembly, will be ignored by cad. Thus the changes make from the components drawing will be discarded.</div><div>&nbsp;</div><div>Regards</div><div>&nbsp;</div><div>Roddo</div>]]>
   <pubDate>Sun, 02 Oct 2011 03:35:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17259&amp;title=insert-same-name-block#17259</guid>
   <title><![CDATA[Insert same name Block ? : You want to be able to have two...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17253&amp;title=insert-same-name-block#17253</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6682<br /><strong>Posted:</strong> 30.Sep.2011 at 12:33<br /><br />You want to be able to have two blocks with the<i> exact same name</i> in one drawing?]]>
   <pubDate>Fri, 30 Sep 2011 12:33:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17253&amp;title=insert-same-name-block#17253</guid>
   <title><![CDATA[Insert same name Block ? : Greeting all I am new to forum...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17239&amp;title=insert-same-name-block#17239</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=218542">Roddo</a><br /><strong>Subject:</strong> 6682<br /><strong>Posted:</strong> 30.Sep.2011 at 01:43<br /><br /><DIV>Greeting all</DIV><DIV>I am new to forum and I have a question with regard to insert block. Is the a way to allow auto cad to accept an identical name from another drawing. At works , we splitting our drawing up into smaller drawings, updating block using&nbsp;refedit&nbsp;and then copy it back to the master drawing. But because the master drawing already has the same block name, changed make to the blocks in the small drawing&nbsp;are not update and ignored. Is the a way to updating this, rather changing the block name every times.</DIV><DIV>&nbsp;</DIV><DIV>Thanks all.</DIV><DIV>&nbsp;</DIV><DIV>Roddo</DIV>]]>
   <pubDate>Fri, 30 Sep 2011 01:43:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6682&amp;PID=17239&amp;title=insert-same-name-block#17239</guid>
