  <title>CAD Forum discussion (EN) : DWG to PDF</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : DWG to PDF]]></description>
  <pubDate>Sun, 05 Jul 2026 18:08:27 +0000</pubDate>
  <lastBuildDate>Tue, 31 Jan 2012 22:09:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6727</WebWizForums:feedURL>
   <title><![CDATA[DWG to PDF : you can print only, on the printer/plotter...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=18840&amp;title=dwg-to-pdf#18840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=250110">vmonrroy</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 31.Jan.2012 at 22:09<br /><br /><P>you can print only, on the printer/plotter name select DWG to PDF, easy.</P><DIV>regards</DIV>]]>
   <pubDate>Tue, 31 Jan 2012 22:09:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=18840&amp;title=dwg-to-pdf#18840</guid>
   <title><![CDATA[DWG to PDF : You can use ClassicPDF editor...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=18748&amp;title=dwg-to-pdf#18748</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=246247">AdamZissman</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 26.Jan.2012 at 12:06<br /><br />You can use ClassicPDF editor for the conversion, it can convert nearly 500+ printable files into PDF, it just installs a simple printer driver during installation, and then you just have to click print for any file and select classicPDF as printer and click print and then file is converted into a PDF file. I hope this works well for you!]]>
   <pubDate>Thu, 26 Jan 2012 12:06:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=18748&amp;title=dwg-to-pdf#18748</guid>
   <title><![CDATA[DWG to PDF : It is my first come here and see...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17753&amp;title=dwg-to-pdf#17753</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=229685">Heblye</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 12.Nov.2011 at 02:46<br /><br />It is my first come here and see the articles, i think it is good, so i leave my footprint, and the forum is usefull for me, i will come back]]>
   <pubDate>Sat, 12 Nov 2011 02:46:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17753&amp;title=dwg-to-pdf#17753</guid>
   <title><![CDATA[DWG to PDF : u can use primo pdf if Plot to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17735&amp;title=dwg-to-pdf#17735</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=124949">CAD library</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 10.Nov.2011 at 16:39<br /><br />u can use primo pdf if Plot&nbsp;<span style="font-size: 11px; text-align: left; : rgb(228, 234, 242); ">to the printer "DWG To PDF.pc3" does not work.....</span>]]>
   <pubDate>Thu, 10 Nov 2011 16:39:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17735&amp;title=dwg-to-pdf#17735</guid>
   <title><![CDATA[DWG to PDF : Find, download and try CutePDF...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17458&amp;title=dwg-to-pdf#17458</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 19.Oct.2011 at 00:31<br /><br />Find, download and try CutePDF instead.]]>
   <pubDate>Wed, 19 Oct 2011 00:31:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17458&amp;title=dwg-to-pdf#17458</guid>
   <title><![CDATA[DWG to PDF : When I convert Autocad to a PDF...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17457&amp;title=dwg-to-pdf#17457</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=74031">ronhill</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 18.Oct.2011 at 20:00<br /><br />When I convert Autocad to a PDF file, the plot crashes. Any suggestions?]]>
   <pubDate>Tue, 18 Oct 2011 20:00:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17457&amp;title=dwg-to-pdf#17457</guid>
   <title><![CDATA[DWG to PDF : You have to be in AutoCAD to use...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17352&amp;title=dwg-to-pdf#17352</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 08.Oct.2011 at 11:58<br /><br />You have to be in AutoCAD to use either command.]]>
   <pubDate>Sat, 08 Oct 2011 11:58:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17352&amp;title=dwg-to-pdf#17352</guid>
   <title><![CDATA[DWG to PDF : Please elaborate these commands..how...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17351&amp;title=dwg-to-pdf#17351</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=220414">rshu</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 08.Oct.2011 at 11:51<br /><br />Please elaborate these commands..how to use these for converting through windows command prompt?]]>
   <pubDate>Sat, 08 Oct 2011 11:51:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17351&amp;title=dwg-to-pdf#17351</guid>
   <title><![CDATA[DWG to PDF : Either PLOT (to the printer &amp;#034;DWG...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17350&amp;title=dwg-to-pdf#17350</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 08.Oct.2011 at 11:34<br /><br />Either &#091;CMD&#093;PLOT&#091;/CMD&#093; (to the printer "DWG To PDF.pc3") or &#091;CMD&#093;EXPORTPDF&#091;/CMD&#093;.]]>
   <pubDate>Sat, 08 Oct 2011 11:34:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17350&amp;title=dwg-to-pdf#17350</guid>
   <title><![CDATA[DWG to PDF : What are the commands used in...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17349&amp;title=dwg-to-pdf#17349</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=220414">rshu</a><br /><strong>Subject:</strong> 6727<br /><strong>Posted:</strong> 08.Oct.2011 at 07:31<br /><br />What are the commands used in autocad to convert dwg to pdf? Please help..]]>
   <pubDate>Sat, 08 Oct 2011 07:31:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6727&amp;PID=17349&amp;title=dwg-to-pdf#17349</guid>
