  <title>CAD Forum discussion (EN) : Add hatches to Autocad 2012</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Add hatches to Autocad 2012]]></description>
  <pubDate>Wed, 09 Sep 2026 06:24:44 +0000</pubDate>
  <lastBuildDate>Fri, 14 Oct 2011 19:24:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6751</WebWizForums:feedURL>
   <title><![CDATA[Add hatches to Autocad 2012 : Thank you. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17414&amp;title=add-hatches-to-autocad-2012#17414</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 19:24<br /><br />Thank you. ]]>
   <pubDate>Fri, 14 Oct 2011 19:24:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17414&amp;title=add-hatches-to-autocad-2012#17414</guid>
   <title><![CDATA[Add hatches to Autocad 2012 :   Listen very carefully. As...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17412&amp;title=add-hatches-to-autocad-2012#17412</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 18:39<br /><br />Listen very carefully.&nbsp; <br><br>As long as AutoCAD knows where to find the folder it will find your .pat file.&nbsp; It could be on the far side of the moon and AutoCAD wouldn't care.&nbsp; That is why one types in the "path" to their file.&nbsp; Consider this "path" to be like a trail of bread crumbs to a hungry animal.&nbsp; It will find the source.<br><br>If you want to put your .pat file(s) where AutoCAD does then make sure you know what the correct folder is.&nbsp; One way to obtain this information is to type (findfile"acad.pat") at the command line then press Enter.&nbsp; AutoCAD will display the "path" to the hatch pattern file currently being used by the program.&nbsp; <br><br>WARNING!<br><br>One downside to placing custom files in the AutoCAD folder is that you could overwrite the folder contents or the folder is deleted for some reason (maybe an upgrade?).&nbsp; There goes your custom files.&nbsp; Bye, bye.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 14.Oct.2011 at 18:41</span>]]>
   <pubDate>Fri, 14 Oct 2011 18:39:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17412&amp;title=add-hatches-to-autocad-2012#17412</guid>
   <title><![CDATA[Add hatches to Autocad 2012 : My folder with my new PAT hatches...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17411&amp;title=add-hatches-to-autocad-2012#17411</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 17:26<br /><br /><P>My folder with my new PAT hatches is somewhere in the C drive. Isn't there an specific folder where hatches live? Otherwise, I believe Autocad will not find the new hatches. </P>]]>
   <pubDate>Fri, 14 Oct 2011 17:26:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17411&amp;title=add-hatches-to-autocad-2012#17411</guid>
   <title><![CDATA[Add hatches to Autocad 2012 : Click on the ADD button to the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17410&amp;title=add-hatches-to-autocad-2012#17410</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 16:54<br /><br />Click on the ADD button to the right and then add the "path" to the folder containing your new .pat file(s).]]>
   <pubDate>Fri, 14 Oct 2011 16:54:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17410&amp;title=add-hatches-to-autocad-2012#17410</guid>
   <title><![CDATA[Add hatches to Autocad 2012 : I&amp;#039;m in the options dialog...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17409&amp;title=add-hatches-to-autocad-2012#17409</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 16:52<br /><br /><P>I'm in the options dialog box, I opened the "Support File Search Path" I see a "C\program files\autodesk\2012-english\support". What is next? Thank you. </P>]]>
   <pubDate>Fri, 14 Oct 2011 16:52:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17409&amp;title=add-hatches-to-autocad-2012#17409</guid>
   <title><![CDATA[Add hatches to Autocad 2012 : Put the hatch pattern in a folder...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17408&amp;title=add-hatches-to-autocad-2012#17408</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 16:39<br /><br />Put the hatch pattern in a folder that is in the support file search path of AutoCAD.]]>
   <pubDate>Fri, 14 Oct 2011 16:39:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17408&amp;title=add-hatches-to-autocad-2012#17408</guid>
   <title><![CDATA[Add hatches to Autocad 2012 : How do I add already created hatches...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17407&amp;title=add-hatches-to-autocad-2012#17407</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 6751<br /><strong>Posted:</strong> 14.Oct.2011 at 16:31<br /><br /><P>How do I add already created hatches to Autocad 2012? I have PAT files from someone else. </P><span style="font-size:10px"><br /><br />Edited by ncespedes - 14.Oct.2011 at 16:39</span>]]>
   <pubDate>Fri, 14 Oct 2011 16:31:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6751&amp;PID=17407&amp;title=add-hatches-to-autocad-2012#17407</guid>
