  <title>CAD Forum discussion (EN) : Drawing file is not Valid</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Drawing file is not Valid]]></description>
  <pubDate>Sat, 31 Oct 2026 04:32:14 +0000</pubDate>
  <lastBuildDate>Wed, 19 Oct 2011 11:52:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6776</WebWizForums:feedURL>
   <title><![CDATA[Drawing file is not Valid : First check Tip 5102-Drawing file...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6776&amp;PID=17471&amp;title=drawing-file-is-not-valid#17471</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6776<br /><strong>Posted:</strong> 19.Oct.2011 at 11:52<br /><br />First check Tip 5102-Drawing file is not valid (error).&nbsp; It is listed as a related CAD tip under your post.<br><br>Note: You can download, for free, AutoDesk DWG Trueview to open drawings and save them to an earlier file format.<br>]]>
   <pubDate>Wed, 19 Oct 2011 11:52:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6776&amp;PID=17471&amp;title=drawing-file-is-not-valid#17471</guid>
   <title><![CDATA[Drawing file is not Valid : I need help withtwofilesthat do...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6776&amp;PID=17463&amp;title=drawing-file-is-not-valid#17463</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=223120">RGFRGF</a><br /><strong>Subject:</strong> 6776<br /><strong>Posted:</strong> 19.Oct.2011 at 01:14<br /><br /><span ="Apple-style-span" style="color: rgb(51, 51, 51); font-family: arial, sans-serif; font-size: 16px; : rgb(245, 245, 245); "><span ="hps">I need help with</span>&nbsp;<span ="hps">two</span>&nbsp;<span ="hps">files</span>&nbsp;<span ="hps">that do not open</span>&nbsp;<span ="hps">files</span><span>.</span>&nbsp;<span ="hps">When you open</span>&nbsp;<span ="hps">the</span>&nbsp;<span ="hps">autocad</span>&nbsp;<span ="hps">gives</span>&nbsp;<span ="hps">an</span>&nbsp;<span ="hps">error</span><span ="hps">file is not</span>&nbsp;<span ="hps">valid.</span>&nbsp;<span ="hps">Anyone</span>&nbsp;<span ="hps">can help me</span><span>?</span><br><span ="hps">The files</span>&nbsp;<span ="hps">are in the following</span>&nbsp;<span ="hps">link:</span>&nbsp;<span ="hps">http://wtrns.fr/RMlHL7XgNw-rAA</span><br><span ="hps">thank you</span></span>]]>
   <pubDate>Wed, 19 Oct 2011 01:14:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6776&amp;PID=17463&amp;title=drawing-file-is-not-valid#17463</guid>
