  <title>CAD Forum discussion (EN) : LinOut utility</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : LinOut utility]]></description>
  <pubDate>Sun, 01 Nov 2026 22:20:56 +0000</pubDate>
  <lastBuildDate>Fri, 28 Oct 2011 17:19:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6809</WebWizForums:feedURL>
   <title><![CDATA[LinOut utility : Please note that complex linetypes...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17595&amp;title=linout-utility#17595</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6809<br /><strong>Posted:</strong> 28.Oct.2011 at 17:19<br /><br />Please note that complex linetypes may depend on other files - shape definitions (SHX). Post the complaining line of your linetype definition. You will probably need to add the missing SHX file to your target workstation.]]>
   <pubDate>Fri, 28 Oct 2011 17:19:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17595&amp;title=linout-utility#17595</guid>
   <title><![CDATA[LinOut utility : Post the linetype file. Maybe...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17593&amp;title=linout-utility#17593</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6809<br /><strong>Posted:</strong> 28.Oct.2011 at 11:58<br /><br />Post the linetype file.&nbsp; Maybe someone here can take a look at it and figure out why it won't work.]]>
   <pubDate>Fri, 28 Oct 2011 11:58:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17593&amp;title=linout-utility#17593</guid>
   <title><![CDATA[LinOut utility : when I try to load the just extrcted...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17589&amp;title=linout-utility#17589</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=221675">el_amigo</a><br /><strong>Subject:</strong> 6809<br /><strong>Posted:</strong> 28.Oct.2011 at 00:51<br /><br />when I try to load the just extrcted line type into a new drawing I get an error message saying " Bad definition of *<EM>line type name* </EM>at line 6 of file C:\Documents and Settings\*\*\Linetype.lin&nbsp;&nbsp; &amp; will not load any line type<DIV>&nbsp;</DIV><DIV>thanks</DIV>]]>
   <pubDate>Fri, 28 Oct 2011 00:51:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17589&amp;title=linout-utility#17589</guid>
   <title><![CDATA[LinOut utility : What do you mean &amp;#034;it will...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17584&amp;title=linout-utility#17584</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6809<br /><strong>Posted:</strong> 27.Oct.2011 at 11:40<br /><br />What do you mean "it will not work"?&nbsp; You cannot load the linetype?]]>
   <pubDate>Thu, 27 Oct 2011 11:40:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17584&amp;title=linout-utility#17584</guid>
   <title><![CDATA[LinOut utility : Hi  I just download the LineOut...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17580&amp;title=linout-utility#17580</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=221675">el_amigo</a><br /><strong>Subject:</strong> 6809<br /><strong>Posted:</strong> 27.Oct.2011 at 01:05<br /><br />Hi <DIV>I just download the LineOut utility to extract line type definitions but when I create the linetype definition file, it will not work in othe drawings, help........<img src="http://www.cadforum.cz/forum_en/smileys/smiley5.gif" height="17" width="17" border="0" align="absmiddle" alt="C&#111;nfused" /></DIV><DIV>&nbsp;</DIV><DIV>Cheers</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><span style="font-size:10px"><br /><br />Edited by el_amigo - 27.Oct.2011 at 01:29</span>]]>
   <pubDate>Thu, 27 Oct 2011 01:05:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6809&amp;PID=17580&amp;title=linout-utility#17580</guid>
