  <title>CAD Forum discussion (EN) : Change of Layer Attributes</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Change of Layer Attributes]]></description>
  <pubDate>Wed, 22 Apr 2026 22:02:36 +0000</pubDate>
  <lastBuildDate>Tue, 01 Nov 2011 07:20:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6813</WebWizForums:feedURL>
   <title><![CDATA[Change of Layer Attributes : Will do that and post the result.Thanks...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17629&amp;title=change-of-layer-attributes#17629</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=195093">rogzimmi</a><br /><strong>Subject:</strong> 6813<br /><strong>Posted:</strong> 01.Nov.2011 at 07:20<br /><br />Will do that and post the result.<br><br>Thanks very much.<br><br>]]>
   <pubDate>Tue, 01 Nov 2011 07:20:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17629&amp;title=change-of-layer-attributes#17629</guid>
   <title><![CDATA[Change of Layer Attributes : A script might be a set of instructions...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17621&amp;title=change-of-layer-attributes#17621</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6813<br /><strong>Posted:</strong> 31.Oct.2011 at 11:23<br /><br />A script might be a set of instructions that open a drawing, make changes to a layer name and color, purge, audit (check for errors), do a zoom &gt; extents then a save.&nbsp; It would cycle through a folder or directory of drawings doing this to each and every drawing.<br><br>Check out AutoDesk's free ScriptPro at their website.<br>]]>
   <pubDate>Mon, 31 Oct 2011 11:23:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17621&amp;title=change-of-layer-attributes#17621</guid>
   <title><![CDATA[Change of Layer Attributes : A script. Although I use AutoCad...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17613&amp;title=change-of-layer-attributes#17613</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=195093">rogzimmi</a><br /><strong>Subject:</strong> 6813<br /><strong>Posted:</strong> 31.Oct.2011 at 01:12<br /><br />A script. <br>Although I use AutoCad since version 2.16 I never realy got into the deep end of it I can do some lisp program but not much more mate.<br>I discovered just recently how to record a macro, would that do the trick?<br>Will try<br><br>thanks<br><br>Rog<br>]]>
   <pubDate>Mon, 31 Oct 2011 01:12:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17613&amp;title=change-of-layer-attributes#17613</guid>
   <title><![CDATA[Change of Layer Attributes : I don&amp;#039;t think you can make...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17594&amp;title=change-of-layer-attributes#17594</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6813<br /><strong>Posted:</strong> 28.Oct.2011 at 12:00<br /><br />I don't think you can make wholesale changes.&nbsp; Maybe the best you could do is write a script and let it do the drudge work.]]>
   <pubDate>Fri, 28 Oct 2011 12:00:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17594&amp;title=change-of-layer-attributes#17594</guid>
   <title><![CDATA[Change of Layer Attributes : Hello AllI have a Library with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17590&amp;title=change-of-layer-attributes#17590</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=195093">rogzimmi</a><br /><strong>Subject:</strong> 6813<br /><strong>Posted:</strong> 28.Oct.2011 at 03:34<br /><br />Hello All<br>I have a Library with blocks which I made and since we are doing work for a big client, we have to comply with his CAD standards such as Layer names and colours.<br>My question is :<br>is there a way to make these changes in one go or do I have to open each block and do the changes the old fashion way?<br><br>Rog<br>]]>
   <pubDate>Fri, 28 Oct 2011 03:34:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6813&amp;PID=17590&amp;title=change-of-layer-attributes#17590</guid>
