  <title>CAD Forum discussion (EN) : Coordinates</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Coordinates]]></description>
  <pubDate>Tue, 07 Apr 2026 00:45:06 +0000</pubDate>
  <lastBuildDate>Sun, 30 Oct 2011 18:58:22 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6818</WebWizForums:feedURL>
   <title><![CDATA[Coordinates :  Thank you for your answer Vladimir...I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17612&amp;title=coordinates#17612</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=226109">gardenia</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 30.Oct.2011 at 18:58<br /><br />Thank you for your answer Vladimir...<br><br>I have seen those links but&nbsp; I have some difficulties downloading them.<br>I will try to download them again.<br>Btw I managed to obtain those coordinates by using an application made based on program language....(finally, I can continue on my work <img src="https://www.cadforum.cz/forum_en/smileys/smiley4.gif" border="0" align="absmiddle" alt="Big%20smile" />)<br><br>As a freshman, I found that This forum is really helpful I. I will ask more questions again...I hope all masters in this forum kindly help me haha<br><br>Regards<br><br><br><br><span style="font-size:10px"><br /><br />Edited by gardenia - 30.Oct.2011 at 19:03</span>]]>
   <pubDate>Sun, 30 Oct 2011 18:58:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17612&amp;title=coordinates#17612</guid>
   <title><![CDATA[Coordinates : You can use the Click2XLS tool...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17610&amp;title=coordinates#17610</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 30.Oct.2011 at 18:02<br /><br />You can use the Click2XLS tool (freeware, see the tip 8030) for a mostly manual process or the Curve2XLS tool (shareware, see Download) for an automatic export.<br>]]>
   <pubDate>Sun, 30 Oct 2011 18:02:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17610&amp;title=coordinates#17610</guid>
   <title><![CDATA[Coordinates : Thank you for your replyAfter...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17608&amp;title=coordinates#17608</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=226109">gardenia</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 30.Oct.2011 at 08:07<br /><br />Thank you for your reply<br>After drawing contour lines by using autoCAD, Can I export the coordinates (x,y,z) of those lines to other programs such as excel? In this forum, I found that one can obtain the coordinates using autoCAD 2008. Is there any tool that one can use to find coordinates x,y,z in autoCAD 2007.<br><br>Thank you...<br><br><br>]]>
   <pubDate>Sun, 30 Oct 2011 08:07:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17608&amp;title=coordinates#17608</guid>
   <title><![CDATA[Coordinates : What data do you actually have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17604&amp;title=coordinates#17604</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 29.Oct.2011 at 19:10<br /><br />What data do you actually have that you will be using to create the 3D contours in AutoCAD with?&nbsp; I'm not quite understanding what you are doing.]]>
   <pubDate>Sat, 29 Oct 2011 19:10:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17604&amp;title=coordinates#17604</guid>
   <title><![CDATA[Coordinates : Thanks for the replyYes, I would...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17603&amp;title=coordinates#17603</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=226109">gardenia</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 29.Oct.2011 at 17:43<br /><br />Thanks for the reply<br><br>Yes, I would like to draw a 3D contour of one site. Since I don't have autoCAD civil 3D, I need to get the coordinates from the 2D Autocad. After obtaining the coordinates,&nbsp; I will use them in another program.<br>]]>
   <pubDate>Sat, 29 Oct 2011 17:43:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17603&amp;title=coordinates#17603</guid>
   <title><![CDATA[Coordinates : You could but it is not the best...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17602&amp;title=coordinates#17602</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 29.Oct.2011 at 17:29<br /><br />You could but it is not the best program to be doing contours with.<br><br>I get the feeling that you want to do this in 3D not 2D.&nbsp; Is that correct?<br>]]>
   <pubDate>Sat, 29 Oct 2011 17:29:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17602&amp;title=coordinates#17602</guid>
   <title><![CDATA[Coordinates : Dear all,Hi I am a new user and...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17601&amp;title=coordinates#17601</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=226109">gardenia</a><br /><strong>Subject:</strong> 6818<br /><strong>Posted:</strong> 29.Oct.2011 at 17:20<br /><br />Dear all,<br><br>Hi I am a new user and I would like to ask some question related to use of Autocad<br>1. I use autocad 2007, can I use it to draw contour lines ? Could you give some advise to draw contour lines ?<br>2. How can I obtain not only the coordinate x,y,z of&nbsp; one points but some points because I have hundreds of polyline contours in dwg format and want the detail xy coordinates ?<br><br>Thank you<br><br>]]>
   <pubDate>Sat, 29 Oct 2011 17:20:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6818&amp;PID=17601&amp;title=coordinates#17601</guid>
